Hi fellas I know this has been discussed in much detail so I do apologise but can you clear this up for me, I have ordered a GI PRO with ATRE for my rocket so is there any reason to remove the secondaries? Will the GI PRO not achieve the same result, ie de restrict the lower gears? thanks , mark
Getting the GiPro negates the need to remove the secondaries. As my R3T (2013) is new, a lot of items are only listed up to 2012 at this point. My plan is underseat K&N, TORS and GiPro. Is that a reasonable combination to get this things HP back to a reasonable range?
On other forums I have been reading they say remove secondaries + GiPro, no tune. I have underseat K&N, GiPro secondaries removed...but have an issue which could well be to do with the secondaries being removed.
make SURE if you order a TuneECU cable off e-bay,
to get the one that has blue ends
but a grey or silver cable in the middle. NOT the solid blue on both ends and blue cable.
They're hit an miss, some work, some don't.
no way to tell till ya try it out.
The others, work. blue ends, grey cable,
that's the one ya want...
Related Threads
Triumph Rat Motorcycle Forums
3.9M posts
167.7K members
Since 2002
