As the length of the forks and their components are all fixed length items of the same length, the forks should sit in the triple clamps at the same height.
This is easy to fix, simply lift the bike off the deck with a hydraulic bike stand, loosen the side you want to alter and tap the top of the fork down with a end of a hammer handle until they line up.
A 1.9mm difference in height is probably not going to make a huge difference to tyre wear or handling unless you are wanting to ride at Valentino's type velocities but it might make the axle more difficult to remove than it should when it comes time to remove the front wheel for tyre replacement.
Davo
Only a biker knows why a dog sticks it's head out of a car window
