Hey Dixon, changing your pipes is childs play! Just start undoing the rear footpeg mounting bolts, remove the chrome dresser plates with a 3mm hex tool (Allen key), loosen the muffler clamps at the cat box (14mm socket from memory) and work the pipes away from the bike.
Fitting new pipes is just the opposite procedure. I am not sure if the TORs come with new wire mesh gaskets. If not use the old ones if you can get them out without destroying them!
It's a very easy job. Davo
Only a biker knows why a dog sticks it's head out of a car window
