Cam Roller Noise - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismMotorcycle.comNew Bonneville
Old 08-25-2005, 01:42 PM   #1 (permalink)
Favourite Bike: Rocket III
With about 2900 miles on the Rocket and from idle to about 1500 RPM I hear an unusual tapping noise that is isolated at the front of the bike low in the motor. No impact on performance noted.
Salesman and mechanic confirmed cam roller noise. They expect the noise will disappear in the future as the cam self adjusts or will fix at next maintenance.
Not sure this condition has been reported.
TallRocket is offline   Reply With Quote
Old 08-26-2005, 12:14 AM   #2 (permalink)
The bike has manually adjustable valves, it will NOT self adjust. Take it to another dealer.
Ron
Aussiekeeper is offline   Reply With Quote
Old 08-26-2005, 04:04 AM   #3 (permalink)
"unusual tapping noise that is isolated at the front of the bike low in the motor"
Are you sure that it is a cam roller noise ?
It also could be the clutch assembly which is sometimes very noisely and is located in the front and low in the engine.
And has said Ron, if your dealer told you that the Rocket III has self adjustable valves, don't bring your bike to him anymore.
jacques
There's no substitute for cubic inches !
Trackerjack Photo Album
Trackerjack is offline   Reply With Quote
Old 08-26-2005, 10:58 AM   #4 (permalink)
Perhaps the dealer meant the cam chain will self adjust?? The cam chain has an automatic tensioner. Either way it seems kind of pie in the sky thinking to me. Try pulling in the clutch to see if that affects the noise. Does it only make the noise when the engine is cold?
RocketEd is offline   Reply With Quote
OT - Roller Derby name oregonthruxton Biker Hang-Out 13 02-17-2008 04:47 AM
1995 D12 Cam chain noise tritonwow Daytona Deliberations 4 04-14-2007 04:16 AM
cam chain noise Fixit Trophy 3 12-19-2004 01:07 PM
cam chain noise Fixit Maintenance & Workshop Talk 2 12-19-2004 12:38 PM
cam chain noise Fixit Hinckley Classic Triples 0 12-18-2004 03:08 PM
