Blew a fuse - Triumph Forum: Triumph Rat Motorcycle Forums
Old 08-22-2005, 04:39 AM   #1 (permalink)
Other Motorcycle: BMW K1200 R Sport
The clock had come loose, and I unscrewed the cover to tighten it. Took only 5 minutes.
But in the process I had appearantly toched something inside the clock causing the fuse to blow. And I wasn´t aware of it until I drove away, then I couldn´t get the neutral light to come on, and I thought about all the posts in this forum about readjusting the neutral switch and I cursed silently to my self.
But when I came to the first intersection I turned on the turn signals and they wouldn´t come on either, I realized that I must have blown a fuse.
And for You guys, that like me, haven´t read the manual there is a tiny tool in the fuse box (which in it´s turn is located under the saddle :wink: ) that helps pulling out the small fuses. Wouldn´t have managed with my fat fingers otherwise, that´s for sure!!! :-D
So, the lesson is: disengage the battery before tampering with the clock, it has power on even with ignition off!!! :razz:
Second best after knowing something, is remembering where You read it...
Rocket-tre is offline   Reply With Quote
Old 08-22-2005, 08:05 AM   #2 (permalink)
I'm to scared to even look for the fuses,fortunately the bike is still under warranty, i dont even wanna pull the tank of at the moment.
Re neutral, no probs, but i have to double clutch it every time too even find first.
And as for fat fingers i'll let the missus answer that one!
And, after all that i dont have a clock but thanks anyway.
Moosey is offline   Reply With Quote
Old 08-23-2005, 11:26 PM   #3 (permalink)
Hey Moosey, the fuses are under the seat.
T
tmiller11147 is offline   Reply With Quote
Old 08-24-2005, 05:41 AM   #4 (permalink)
Yes.., and the seat opens with ign.key in right side cover... :wink:
Actually I am glad it happend that way, I was in no hurry, nad I had time to figure it out under no stress and it wasn´t a fuse that took out all the functions. I could have ridden long without it.
It now feels a bit more secure knowing were to find them, and I bought a couple of extra fuses to carry with me.
Old 12-16-2005, 06:01 AM   #5 (permalink)
Did your fuse box cover have that 2 cent rubber band around fuse box?
Robyyy is offline   Reply With Quote
Old 12-16-2005, 09:55 AM   #6 (permalink)
Favourite Bike: 2005 Rocket III
RidinSunshine's Avatar
Yep! Both of ours had that weak rubber band. Honey's broke a long time ago. Think mine is still there.
REAL WOMEN RIDE TRIUMPH
FOR SOME THERE'S THERAPY FOR THE REST OF US THERE'S MOTORCYCLES
RidinSunshine is offline   Reply With Quote
Blew 10 amp fuse using heated grips and access socket sodapop Sprint Forum 20 12-02-2007 05:59 PM
Well, today really blew DuckMan001 Club Cafe' 11 10-09-2007 01:33 PM
Need Help !!!! Radiator Blew..... GsIII The Rocket Science Forum 10 07-03-2006 11:28 AM
Bike blew up glacier Sprint Forum 18 06-30-2006 06:03 AM
My rocket blew up Rod The Rocket Science Forum 26 07-15-2005 06:50 PM
