BikeBanditMotorcycle.com
Old 12-02-2006   #21 (permalink)
On 2006-12-02 11:15, rktmn3 wrote:
Remember all PCIII maps can be converted to use with TuneBoy. If you are concerned with how to do this just send the PCIII to TuneBoy and they will convert it over for you.
Tuneboy has a feature that lets you load a PCIII trim map and apply it to your Triumph tune. However, all of the pcIII maps are based on the triumph stock 20050 map so you need this in the bike before you apply the pcIII trim.
There's another problem with applying a pcIII map. The pcIII has an O2 sensor which overrides the stock sensor which controls the fuel in "closed loop" at the low end. If you load one of these pcIII trim maps with Tuneboy, the ECU is still using the Triumph O2 sensor to control the low end fuel mix. In other words, there's a mismatch. I believe Pig9r has some experience with this.
[ This message was edited by: dougl on 2006-12-02 16:59 ]
dougl is offline   Reply With Quote
Looking for Power commander maps wileytt Triumph SuperSports 3 08-20-2007 12:37 PM
Help with Power Commander Maps Bluetahoe Speed Triple Forum 4 05-29-2007 09:39 PM
2000 Sprint RS power commander custom map. rocketrich Sprint Forum 10 04-18-2006 01:03 AM
Power Commander maps HarriS Speed Triple Forum 3 02-01-2006 11:12 AM
TT Custom Powercommander Maps Triumph SuperSports 3 01-31-2005 06:22 PM
