Making aux brake lights work - Triumph Forum: Triumph Rat Motorcycle Forums
Old 08-13-2005, 01:11 AM   #1 (permalink)
Ok, I tried installing two different auxilary LED brake lights, like Back Off LED panels, on two different bikes (my Rocket and a Honda Shadow) and the results are the same. They just don't seem to work in conjuction with the existing taillights.
If wired per instructions (3 wires: ground, running/tail light, brake light), neither the original or auxilary taillights will work - no light at all or braking function won't work.
I've tried every sensible wiring combo I could and blew more than a few fuses, but in each both cases I had to wire the aux brake light as a running light only.
Are there any wiring tricks I should know about to make these things work like they should - with the existing taillight and not replacing them?
Ty H. - BPMS RAT Pack Leader (MN) My Photo Gallery
RiderRocketman is offline   Reply With Quote
Old 08-13-2005, 01:25 AM   #2 (permalink)
As a wild guess, I would say you may have fried the Led unit by connecting it up backwards. I believe they are polarity sensitive and may not have reverse polarity protection.
Can you confirm it works by connecting to a 12 volt battery, ground wire to the negative terminal?
If it is internally shorted, it will become apparent quickly.
Regards,
Tom
tmiller11147 is offline   Reply With Quote
Old 08-13-2005, 01:37 AM   #3 (permalink)
Yeah, the aux LEDs work fine when used alone such as on a battery or if wired separate from the existing taillight, in which case then the original taillight won't be plugged in.
Old 08-13-2005, 04:58 PM   #4 (permalink)
Yes they are polarity sensitive, but usually they just fail to operate when connected in reverse......
Ron
Aussiekeeper is offline   Reply With Quote
Old 08-13-2005, 06:24 PM   #5 (permalink)
Favourite Bike: 04 Bonnie black
Could the impedence correcting diodes pack be at fault? I have 3 conventional brakelights [small cats eyes] wired in parallel and haven`t had any fuse issues. :???:
Wiring options for aux. driving lights DragonNester Hinckley Classic Triples 12 12-01-2006 05:58 PM
wiring aux lights Harp Tiger Workshop (archive) 5 09-12-2006 12:56 PM
Brake Lights & Turns signals don't work cricket1 Sprint Forum 3 03-30-2006 03:31 PM
Aux Lights Trotts Tiger Mods & Bolt-Ons (archive) 11 10-31-2005 03:03 PM
Aux Lights Fishtale Sprint Forum 15 03-06-2005 09:08 AM
