Anyone have a solution to oil leaking through my starter i have had the dealer look at it and they said i have to replace the o ring on the end of the starter, when i did that i noticed that the oil was actually weeping through the starter. called the dealer and they said that i need a new starter they don't sell internal parts for the starter.
I took the starter apart and noticed an o ring on the inside of the starter and a sealed bearing i can only assume these are the components that are supposed too prevent oil from entering the starter.
My question is has anybody else had this problem and do you have any solutions other than buying another starter.
