Smell of Petrol / Gasoline... - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 11-13-2009, 04:23 PM   #1 (permalink)
Favourite Bike: Claret '08 Rocket III
JRCollings's Avatar
Good afternoon all,
I just want to get your feedback thoughts on the following:
I have noticed that whenever I first turn the bike off, there is a smell of petrol... but if I go back in the garage later, it does not smell.... so I am wondering - is this normal? Should I be concerned? Or?
It has been this way since I collected it from the dealer a month ago - no better, no worse.
Many thanks, John.
JRCollings is offline   Reply With Quote
Old 11-13-2009, 11:57 PM   #2 (permalink)
Favourite Bike: 2005 Rocket III
Other Motorcycle: 2001 Roadking Classic
Extra Motorcycle: 1999 Busa
If i remember my physic correctly. When a gas is heated,the energy of the gas increases. The temperature of the gas will rise,and either the pressure or the volume of the gas(or both) will increase. The ole Rocket can run pretty hot. I keep two bikes in the garage and usually keep the garage door open till they cool off..Check your air-filter and spark plugs if the insulator is black or dark brown your running too rich..
TRIIICK is offline   Reply With Quote
Old 12-02-2009, 08:41 PM   #3 (permalink)
Favourite Bike: Rocket III
I wouldn't worry -
TallRocket is offline   Reply With Quote
Old 12-03-2009, 01:23 PM   #4 (permalink)
JR, I was just wondering did you get the recall on the gas cap, I think it was something about the gasket? cant remember myself but there was a recall and one of the problems was a gas smell! which mine had and it was an intermittent smell! I have not noticed it sence I had the recall done, just an idea? good luck.
12724 is offline   Reply With Quote
gasoline/petrol in airbox mlc Twins Technical Talk 5 08-23-2007 11:39 AM
Petrol (Gasoline) Additive problems. webonnielad Twins Technical Talk 4 08-10-2007 07:41 PM
City Gasoline vs Country Gasoline dawgfan Twins Talk 7 06-19-2006 06:51 PM
oil / petrol smell from exhaust ?? Tiger-G Tiger Workshop (archive) 6 04-12-2006 03:18 AM
Changing air filter, smell of gasoline, removing headers SilverThief T3 Sport / Touring Forum 4 11-27-2005 09:38 AM
