How do I lift the seat? - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismHonda Powersports Motorcycle.comSportbikeTrackGear
Old 10-24-2009, 10:11 PM   #1 (permalink)
Favourite Bike: Claret '08 Rocket III
JRCollings's Avatar
Ok guys, I did a quick forum search, but....
I have the Triumph "touring seat with adjustable backrest" installed..
I read the manual, about turning the key and pushing down on the back of the seat, etc.... but it will not budge, so....
How do I "open" / "get up" my seat?
Many thanks, John.
JRCollings is offline   Reply With Quote
Old 10-24-2009, 11:20 PM   #2 (permalink)
Favourite Bike: 2005 Rocket III
Other Motorcycle: 2001 Roadking Classic
Extra Motorcycle: 1999 Busa
This might help.. FYI... I hit mine with Tri-Flow every once and awhile.
http://www.triumphrat.net/the-rocket...-and-help.html
TRIIICK is offline   Reply With Quote
Old 10-25-2009, 08:48 PM   #3 (permalink)
JRCollings's Avatar
Many thanks Triiick, there was a post in the thread you linked to by Lee that solved the conundrum for me.
I can now get to wiring in my farkles etc (as I can't find an accessory power outlet on the Rocket III).
Old 11-02-2009, 10:42 AM   #4 (permalink)
Favourite Bike: R3 Classic
Other Motorcycle: Bonnieville
Extra Motorcycle: KLR 650
The OEM lanyard to actuate the seat latch is too short. Put a zip tie (Catamount) on the lanyard so you have some purchase and keep it lubed up. It also helps to physically push down on the seat in the area of the release when pulling the lanyard.
The accessory outlet is on the right side (facing firward) just behind the side tin, or tucked under the seat. Has a black cover and also plugs into a battery tender.
You can fool some of the people all of time and all of the people some of the time..........
SidecarFlip is offline   Reply With Quote
Old 11-02-2009, 02:31 PM   #5 (permalink)
JRCollings's Avatar
Thank you very much!
How to Lift an 05-08 ST shemp Sprint Forum 27 02-02-2008 02:02 PM
Lift Dan18 Classic, Vintage & Veteran 4 08-02-2006 04:30 PM
need a lift CCR Maintenance & Workshop Talk 14 03-18-2006 12:18 PM
How to lift the 05 S3 BubbaZ-Isaac Speed Triple Forum 21 10-12-2005 06:37 AM
How do I lift the S4? DaveC Triumph SuperSports 4 05-06-2005 09:48 PM
