rear wheel removal on a rocket three - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-04-2009, 03:45 PM   #1 (permalink)
Newbie
Favourite Bike: triumph thunderbird 900
Other Motorcycle: n/a
Extra Motorcycle: n/a
hi i have just purchased an hydraulic lift to remove my rear wheel to get a new tyre fitted, but i am looking for advice to actually remove my rear wheel i dont want to damage any final drive splines if anyone can help i would really appreciate it a list from start to finish would be most helpful my bike is a rocket 111 2004 classic awaiting replys thankyou all
billbuddy150 is offline   Reply With Quote
Old 10-04-2009, 08:24 PM   #2 (permalink)
Favourite Bike: 2005 Rocket III
Other Motorcycle: 2001 Roadking Classic
Extra Motorcycle: 1999 Busa
I'd suggest you purchace the Service Manual.... Pages 16.8-16.9 walks you through it. I paid $80.00 for it. A dealer will charge up to $500.00 to change and replace the rear tire.
TRIIICK is offline   Reply With Quote
Old 10-05-2009, 08:18 AM   #3 (permalink)
Favourite Bike: ROCKET 3
It's easy to do,
you CAN'T mess it up.
First raise the rear off the ground and ratchet strap the front end tight so nothing moves.
Next pull those two little bent over keepers off your back brake.
loosen up the bleeder bolt and raise the brake caliper off the disc.
Next, take your handy dandy 24MM box end wrench and loosen the axle nut.
Next pull the axle.
Take your right hand and as you squat behind the bike gently pull to the right.
Your back tire is loose.
Don't forget to grease your splines before reassembly.
DO NOT use regular axle grease.
Use a DRY grease. Preferably krytox.
Hope this helps.
xhdskip is offline   Reply With Quote
Old 10-05-2009, 07:44 PM   #4 (permalink)
Favourite Bike: Harley Road King
Other Motorcycle: Rocket III
I just did mine myself, and no problem. You can do it. Since I didn't have a good jack, I used an engine hoist and lifted the rear of the bike up by the upper shock mounts. It isn't too bad of a deal at all and it would be difficult to mess something up. Once you drop the axle spacer and brake caliper arm out of the way, the wheel slides right off of the splines.
roadbosstx is offline   Reply With Quote
Old 10-07-2009, 02:59 AM   #5 (permalink)
Is this for real? $500 !!! I have to assume it's for the tire and labor? WoW...this is a big deal...better start saving for a nomar unit.
jasonworthing is offline   Reply With Quote
Old 10-07-2009, 11:48 AM   #6 (permalink)
Thats what one Triumph dealer quoted me... $324.00 +19.44tax = $343.44 for Tire.Claims two hours labor @ $80.00/hr...$160.00...Total $503.44
Old 10-11-2009, 11:37 AM   #7 (permalink)
CRAP,
I'd go darkside before I'd pay that.
Oh yea,
I already did.
On both the rockets.
rocket III classic wheel removal billbuddy150 The Rocket Science Forum 2 10-03-2009 07:36 AM
rear wheel removal Anomoly Speed Triple Forum 2 08-04-2008 03:21 PM
Rear Wheel Removal tcowjww Tiger Workshop (archive) 3 11-24-2006 07:46 PM
Rear wheel removal Anchorbend Twins Talk 6 04-12-2006 09:35 PM
Rear wheel removal Thunder_Forever Twins Talk 12 09-14-2005 11:28 AM
