Rear Drive Oil Inspection - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-26-2009, 05:56 PM   #1 (permalink)
Favourite Bike: 09 Scrambler
Other Motorcycle: Like an 04 Thunderbird
Not having had a shaft drive bike before, I was curious to see the state of the oil that came out of the bevel box. Although it's not due to be changed yet, I drained it out anyway. What I saw was a bit of a shock...
The glupe that came out was really quite black and didn't look (to me) like it had any lubrication properties left in it... The drain plug (magnetic) had a fair bit of iron sludge stuck to it as well.
Is this to be expected ?
For the small effort involved and the relatively small amout of oil needed ( I think about 170 ml), I think I'll change this stuff every 5K miles. At that rate a 1 lt bottle will yeild at least 25K miles of riding.
Got to be cheaper than a new rear drive assy...
Steve Block is offline   Reply With Quote
Old 09-26-2009, 07:04 PM   #2 (permalink)
Favourite Bike: ROCKET 3
Good call, and yes,
thats to be expected, at least in mine it was about the same.
xhdskip is offline   Reply With Quote
Old 09-26-2009, 08:53 PM   #3 (permalink)
Favourite Bike: 2005 Rocket III
Other Motorcycle: 2001 Roadking Classic
Extra Motorcycle: 1999 Busa
http://www.triumphrat.net/the-rocket...oil-level.html
I experienced the same shock also, i change it every time i change the oil. Like you say 170 ml...
TRIIICK is offline   Reply With Quote
Old 09-27-2009, 09:35 PM   #4 (permalink)
Favourite Bike: 08 Rocket 3
KingOfFleece's Avatar
Other Motorcycle: Bonneville 2009
Changed the rear oil about 20 times on 10 R3's. They all looked like that-and there have been no problems with any of the bikes. Normal, that is. No worry.
KingOfFleece is offline   Reply With Quote
More thinking out loud: Final drive question, why not Belt drive or Shaft drive? rudebwoy85 Speed Triple Forum 13 12-25-2009 08:04 PM
Free play in rear cush drive kredge Sprint Forum 8 05-07-2009 03:04 PM
02 ST Rear cush drive and shock life deller4210 Sprint Forum 3 05-26-2008 07:39 AM
Rear Cush drive on the 02 ST deller4210 Sprint Forum 3 10-21-2007 03:09 PM
Rear drive drain plug Ugarte The Rocket Science Forum 9 08-02-2006 03:54 PM
