I need a new battery and help - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-18-2009, 09:03 PM   #1 (permalink)
Newbie
Exclamation I need a new battery and help
I know this sounds dumb, but I just bought an 05 Classic rocket 3 and the battery is dead. I am not sure where it is located, and I don't want to just pull on the side covers to see if they will break first.
Can someone tell me which side of the bike do you access the battery from.
The side cover on the right side has a a keyed lock. The key turns, but it doesn't seem to release anything.
If it matters, the seat was replaced with a Corbin model.
If the seat needs to be lifted or removed, I'll need some direction with that too. Thanks
dougsko is offline   Reply With Quote
Old 09-18-2009, 09:54 PM   #2 (permalink)
Lee
Multi-Iron Butt Moderator
Favourite Bike: Triumph RIII Graphite
Lee's Avatar
Other Motorcycle: Honda Goldwing 2012 Red
Extra Motorcycle: Is it really ever extra..
Doug hello. I have a graphite 05 as well. It is located under the seat. Use the key in the side cover lock and the pull tab on the opposite side under the seat lift the seat off and the battery is under there. Beings the season is almost over I would recommend you pick up a battery tender to maintain it's charge over the winter.
Good luck with your excellent choice of bikes.
Four Iron Butt Rides Todate....Will Be Working On Longer Ones In The Upcoming Year...Jersey Born and Raised........Texas run 1000 in 24 hours in April 2012
Lee is offline   Reply With Quote
Old 09-19-2009, 12:16 AM   #3 (permalink)
Diego's Avatar
Just a small further thought about the seat...when you release the latch with the key, it doesn't necessarily pop up on its own. In fact, and especially with a non-stock seat, you may have to press down a little toward the back of the seat before you turn the key. Then, once the key is turned as far as it will go, try pulling up on the back of the seat.
John
Old 09-19-2009, 05:38 AM   #4 (permalink)
Favourite Bike: ROCKET 3
You might want to upgrade that battery.
I bought a PC625.
I use to have to jump mine on cold mornings.
But with 625 CCA no more problems in the winter.
The pC625 will just fit in the box, but it's tight.
I eventually pulled my battery box out and bent the front lip down on it.
xhdskip is offline   Reply With Quote
Old 09-26-2009, 06:54 AM   #5 (permalink)
Newbie
new battery
got it. thanks
Old 09-26-2009, 07:15 AM   #6 (permalink)
Doug, did you upgrade your battery?
Old 09-28-2009, 07:40 AM   #7 (permalink)
Newbie
new battery
I replaced it with what was in it. My seat was replaced with a Corbin. That was attached with a couple bolts which needed removed first. Thanks for asking.
Old 10-01-2009, 07:40 PM   #8 (permalink)
might want to get a battery tender for the winter months.
good luck.
Old 10-01-2009, 08:15 PM   #9 (permalink)
Favourite Bike: 2005 Rocket III
Other Motorcycle: 2001 Roadking Classic
Extra Motorcycle: 1999 Busa
Originally Posted by Diego View Post
Just a small further thought about the seat...when you release the latch with the key, it doesn't necessarily pop up on its own. In fact, and especially with a non-stock seat, you may have to press down a little {etc}
Was this designed during the Research and Development stage...
TRIIICK is offline   Reply With Quote
Old 10-02-2009, 03:12 PM   #10 (permalink)
Diego's Avatar
I dunno. You'd have to ask Corbin.
John
It's always the battery denny Hinckley Classic Triples 19 01-04-2010 02:08 PM
battery millwallfcuk Trophy 8 05-10-2008 03:02 PM
S3 battery - RIP again stmike Speed Triple Forum 6 08-09-2007 08:17 PM
battery CCR times 2 Biker Hang-Out 11 07-24-2007 10:24 PM
battery tender OR battery tender junior? dml955i Speed Triple Forum 4 11-03-2006 09:12 PM
