Soupy's Performance
Old 09-16-2009, 09:10 PM   #1 (permalink)
Newbie
Question PC3 05 ROCKET 3 Question
I purchased a 05 Rocket 3 with Jardiens and pc 3 with K&N Filters
My question is, when the rocket gets warm I get a profuse stalling problem. Just had it dynoed and runs perfect but yesterday I ran the bike for 3 Plus hours started back firing and not holding Idol?? Wonder if pc3 is susceptible to getting hot and changing settings or What
Thanks in advance
Markn2147d
markn2147d is offline   Reply With Quote
Old 09-19-2009, 04:51 AM   #2 (permalink)
Favourite Bike: ROCKET 3
Martin,
To answer your question, I'd have to know where your PC3 is located.
IF its behind the right or left side cover then no, it should be fine there, as that's where mine is.
What you may be looking at is a bad TPS.
There's two on your bike, the primary is the one that goes out.
My bike was idling up to 3200 RPM's and back down to 800 intermittently.
I could wiggle the wires coming out of the TPS and it'd straighten out for a while.
Triumph is replacing them with a new model.
They've been replacing them with exactly the same one, just new, which fixed the problem for awhile,
but now there's a new one and a new part number for it.
The dealers aren't allowed to put the replacment ones on.
They have to wait on the new ones to arrive from England.
The first ones arrive Wednesday.
The old part # T 1245003
The new part # T 1245113
According to Triumph of Tulsa.
xhdskip is offline   Reply With Quote
Old 09-19-2009, 05:02 AM   #3 (permalink)
Welcome to the forum and welcome to the grin factory.
You bought a great bike.
Old 09-19-2009, 11:02 AM   #4 (permalink)
Newbie
Bad Interermintent problem
Thanks for your info Mike
I am also thinking that it may be bad gas
I am trying to track th problem and its never when I have a full tank of fuel ??
my pc is in the right cover tywraped over the ecm ? O ther than that what a ruch riding this bike crusing at 70 than down shifting to 4 geat and taking off like a Rocket/
the dyno seemed to be ok 147 hp and 136 tork it toped out in fourth gear at 130 andy ideas? Thanks again Mark 2147d
Old 09-19-2009, 07:43 PM   #5 (permalink)
Favourite Bike: Gotta be the Rocket
Other Motorcycle: Honda Dio 50
I have Jardine Big Boss pipes on my R3 and the bike does backfire if I shut the throttle down and cruise up to the lights etc. It has always done this and as I bought it new and fitted the pipes staight on I dont know what it was like before the pipes. Sounds a bit cool tho. Not hard to rectify, just open the throttle a bit, dont leave it shut for so long. There is a gap in the pipe at the join under the right side where the pipe branches to left and right, not sure if this is the problem, tried to seal it but didn't work. I also use high octane gas, 98, and this helps, was reccemmended to me by the local mechanic. ( Harley machanic but we wont hold that against him ). As for the the stalling problem, I think this is peculiar to the R3, but also the 98oct gas has helped here too.
nungers is offline   Reply With Quote
Old 09-19-2009, 07:48 PM   #6 (permalink)
Extra 20hp
If you have Jardines you should be getting an extra 20hp from the bike, total of 165hp, it is even stamped on the side of the right pipe !!!!
Old 09-19-2009, 08:51 PM   #7 (permalink)
Newbie
Mabe solved Problem
I put on about 100 miles today and think solved the problem with high octain fuel and textron addative no stalling problems after about a half hour ! hope is blissfull
Markn2147d
Replacing Rear Brake Pads on Rocket question gsmitty The Rocket Science Forum 8 07-18-2008 02:42 PM
Rocket III vs Rocket III Classic odie The Rocket Science Forum 6 06-19-2008 09:01 PM
The Albrex Triumph Rocket III Turbo: "Rocket Roll!" KingBear The Rocket Science Forum 3 12-06-2007 11:35 PM
Rocket 3 Classic V Rocket 3 Robyyy The Rocket Science Forum 7 07-03-2006 02:12 PM
Not really a rocket science question but... AdmiralRocket The Rocket Science Forum 5 12-30-2005 08:43 AM
