EPG MotoMotorcycle.com Classifieds!SportbikeTrackGearMotorcycle.comBritish Motorcycle GearTrident-Exhausts.comSoupy's Performance
Old 09-15-2009, 10:25 AM   #1 (permalink)
Favourite Bike: Harley Road King
Other Motorcycle: Rocket III
Rocket III won't start
Hello Forum,
I'm a newbie to Triumphs but have lots of motorcycle years under my belt. Have an 05 Rocket III, 10K miles, ran fine last week. Now will not start. Cranks fine, but won't attempt to fire up. haven't checked for fire or fuel into the engine yet. Any secrets that I need to know?
Thank you in advance for any help!
roadbosstx is offline   Reply With Quote
Old 09-15-2009, 11:33 AM   #2 (permalink)
Favourite Bike: Rocket 3 Touring
Sorry don't have any secrets but I would'nt waste time, Get it in for service
I shall pass through this world but once. Any good therefore that I can do or any kindness that I can show to any human being, let me do it now. Let me not defer or neglect it, for I shall not pass this way again.
- Mahatma Gandhi
CTCruiser is offline   Reply With Quote
Old 09-15-2009, 01:29 PM   #3 (permalink)
Favourite Bike: Rocket III classic
grizzly adams's Avatar
Other Motorcycle: Tiger 955
Extra Motorcycle: ZZR600
And check you haven't accidently hit the kill switch
grizzly adams is offline   Reply With Quote
Old 09-15-2009, 02:56 PM   #4 (permalink)
It's likely a relay
Piece of cake. It's probably a bad 12v relay.
Just swap out the available relays until you ID the bad one. There are a few (4-5?) available (3+ behind the left-side pannel, another 1 or 2 under the tank).
If you find which one is bad, you can ride to the nearest auto store and pick up another one for about $6.
(Can you tell that I just went through this?)
Good luck.
2009 Eclipse/Azure Rocket III Touring.
Most motorcycle problems are caused by the nut that connects the handlebars to the saddle.
R3T Convert is online now   Reply With Quote
Old 09-15-2009, 06:18 PM   #5 (permalink)
Thanks guys. I will try the relay elimination process. I live 250 miles to the nearest dealer and like to do my own wrenching anyway. Yes, I did check the kill switch (been there done that) but the Rocket won't even turn over if the kill switch is in the off position.
Old 09-15-2009, 10:26 PM   #6 (permalink)
By relay you mean fuse? Tell me more. I also have an 05 with a 15k, are these relays something that we/I should keep with the tool kit? I will go pull that panel tomorrow and take a look.
TallRocket is offline   Reply With Quote
Old 09-16-2009, 02:03 AM   #7 (permalink)
Diego's Avatar
No. Relays and fuses are very different electrical components. Relays are devices containing an electromagnetic coil and some contacts that the electromagnet can pull closed, allowing a small amount of current (such as the output of a control line from the ECU, or the starter button on the handlebar) to switch a larger current on or off, on command.
Physically, the ones you'll find in a motor vehicle tend to be rectangular plastic boxes with pins on the base, which fit into sockets.
You can if you like, but there's really not much point unless you're away from civilization a lot. They're pretty dependable on average, and as R3T Convert said, most types are widely available at automotive stores.
John
Old 09-16-2009, 09:15 AM   #8 (permalink)
Thanks again R3T Convert. Did some relay swapping last night and Walla!, she fired right up. Went to the parts house and got a new one this morning.
Old 09-16-2009, 10:55 AM   #9 (permalink)
Glad I could help. Sometimes we just don't need the dealer!
Old 09-19-2009, 05:10 AM   #10 (permalink)
Favourite Bike: ROCKET 3
Glad that fixed your problem.
Also be aware that it could have been you ignition switch,
some have been known to go out.
We tore one open at Maggie Valley and resoldered it in May.
fixed the brothers problem.
xhdskip is offline   Reply With Quote
Cold start, Backfire, Now won't start Alterna T3 Sport / Touring Forum 15 12-15-2008 01:48 AM
Rocket III vs Rocket III Classic odie The Rocket Science Forum 6 06-19-2008 09:01 PM
The Albrex Triumph Rocket III Turbo: "Rocket Roll!" KingBear The Rocket Science Forum 3 12-06-2007 11:35 PM
Rocket 3 Classic V Rocket 3 Robyyy The Rocket Science Forum 7 07-03-2006 02:12 PM
Can't push start the Rocket Disco The Rocket Science Forum 14 04-09-2006 12:30 PM
