help needed with Rocket III - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearHonda Powersports Motorcycle.comNew BonnevilleOntario Tourism
Old 09-06-2009, 01:04 AM   #1 (permalink)
Newbie
Hey, I am hoping someone has a suggestion for the problem I am having. My tail light and the light above the license plate are not working. The brake light is working. Thanks for helping.
holtdentalcare is offline   Reply With Quote
Old 09-06-2009, 06:06 AM   #2 (permalink)
I'm assuming the headlight is working or the bike wouldn't start, so chances are the tail light bulb is bad. There are two filaments in the bulb, one for the tail light and one for the brake light. Every gas station has them. I believe the number is 1137.
Mike
06 classic
Wimpy is offline   Reply With Quote
Old 09-06-2009, 11:00 AM   #3 (permalink)
Newbie
tail light prob
yea i did that and the problem has stayed the same.
Old 09-06-2009, 11:37 AM   #4 (permalink)
I had the same problem. Pull the bulb assembly out and take a close look at the wiring. One of my wires had been rubbed raw and was shorting out. I taped over it and its been fine ever since.
Ugarte is offline   Reply With Quote
Old 09-06-2009, 02:49 PM   #5 (permalink)
Diego's Avatar
Originally Posted by Wimpy View Post
I'm assuming the headlight is working or the bike wouldn't start...
Well, you know what they happens when you assume. It is entirely possible for the headlamp to be burnt out or unplugged, and yet for the bike to start anyway. There is no current sensor or interlock to prevent it.
The myth got started when someone noticed that the lights share the fuse and relay of the starter circuit, and then added up two plus two to make six. While it's true that the lights will not work if the fuse is blown or the relay is out of circuit, the reverse is not true. Functioning lights are not necessary for the starter to work. Just the opposite, in fact--the headlights are actually off while the starter is cranking! The only reason the headlamp circuit passes through the starter relay is because that's the easiest way to kill current to the bulb when you press the start button, leaving all the battery's power available to the starter motor.
Since new bulbs didn't fix the problem in this case, I endorse Ugarte's advice. Check for damaged wiring, or maybe the possibility of a connector being loose. The wire feeding these lights should be a yellow one. It runs back to fuse 10, which you may also want to check if you haven't already.
(Interesting side note: the tail light and license plate bulbs do have one thing in common with the headlights, albeit remotely. The same circuit, via a different path, also feeds the small bulbs in the headlight assemblies...the ones Triumph calls "position light" bulbs. If you find fuse 10 blown, but the wiring back to the tail light and license light seems OK, then you might want to start checking frontwards for a shorted wire as well.)
John
Old 09-06-2009, 08:06 PM   #6 (permalink)
Favourite Bike: 2005 Rocket III
Other Motorcycle: 2001 Roadking Classic
Extra Motorcycle: 1999 Busa
Originally Posted by Diego View Post
Well, you know the saying about what happens when you assume. It is entirely possible for the headlamp to be burnt out or unplugged, and yet for the bike to start anyway.
Thanks for putting that myth to rest, every long distance ride i've carried extra bulbs. Now that i've seen the light i can put that worry behind me..
TRIIICK is offline   Reply With Quote
Old 09-06-2009, 11:34 PM   #7 (permalink)
Diego's Avatar
Enlightenment is our goal....
John
Old 09-07-2009, 07:32 PM   #8 (permalink)
Newbie
Checked bulbs and they are okay. Yes the tail light the light above the license plate and the small lights in the headlights are out. The fuse seems to be okay as well. Checked wiring for any areas that may have rubbed away and things look good. Now I did have the ignition replaced about a month ago because it had a short. Would the ignition have anything to do with this problem? Is there any other areas I need to be checking?
Old 09-07-2009, 09:28 PM   #9 (permalink)
Diego's Avatar
The ignition should have no direct effect on that lighting circuit, although there could have been a connector not reconnected during that work, or a wire broken internally in the wiring loom, or a similar fault.
You say the fuse "seems" to be OK. Did you substitute it with a good one, or actually check the continuity with an ohmmeter? If so, the next step in troubleshooting would be to see if you have 12 volts present at the hot side of the socket for fuse 10 when the ignition switch is turned on.
John
Joe Rocket Atomic 3 jacket review needed redmosquito1 Sprint Forum 5 09-18-2008 10:43 AM
Rocket III vs Rocket III Classic odie The Rocket Science Forum 6 06-19-2008 10:01 PM
The Albrex Triumph Rocket III Turbo: "Rocket Roll!" KingBear The Rocket Science Forum 3 12-07-2007 12:35 AM
Rocket 3 Classic V Rocket 3 Robyyy The Rocket Science Forum 7 07-03-2006 03:12 PM
Rocket Trunk - Fabricator Needed Royal-R3 The Rocket Science Forum 8 04-20-2006 08:05 AM
