Originally Posted by jrhorton
changed mine last weekend. The procedure is in the factory service manual. Bike needs to be upright, so you did good.
Stayed with Mobil 1 75W-90. I called the tech line and it is equivalent to the Mobilube 75W/90 SHC listed in the shop manual. Mine had some crud on the magnetic plug and the oil was discolored from the spline lube for the bevel box. Flushed it until it ran fairly clear, then filled.
That fill plug is definitely on there tight. 60 Nm. Good advice to loosen before standing the bike upright....that's what I did too.
That's exactly what i did also. I noticed the crud on the plug. I ended up using a piece of 1 3/8" pipe over the wrench to break the plug loose.
Originally Posted by Diego
Well, viscosity itself has no ability to prevent molecular shear. The two things are largely unrelated. The whining sound is also no indication of same.
Extra viscosity means extra frictional loss in the oil itself and extra heating. I can't think of any legitimate technical reason to use heavier oil than recommended.
I stayed with the Mobil 75W-90,I got caught up in an oil debate on another forum and seems ,well you know how those oil debates go..
