Motorcycle.com
Old 06-08-2005   #1 (permalink)
Over the last couple of weeks the bike has not been going "well"
It was missing sometimes, and sort of "hung back" when opening the throttle...
It was even getting worse, until last week it would only work if the throttle was cracked open.
- I had even asked here "I always use the kill switch, is this a possible reason? "
Diego, of Georgia, USA had replied on the posting "I wouldn't say it's impossible, but it doesn't seem too likely. Starting and idle are the most likely to be affected. "
Thanks bro', you were spot on. It was not the problem.
I was clutching at straws!
The shop could not find the problem, and Triumph's first advice was to take it on a ride to see if it gets better or worse!!!
I was not happy !
Today the owner brought his own rocket in, and the mechanic swapped tanks and pumps...... magic, problem solved.
New pump on order, and a loan of a 1200 Trophy until the pump comes from across the water.
[ This message was edited by: cookies on 2005-06-08 10:25 ]
Smart by natural selection.....
Drink kills off my slower brain cells!!
cookies is offline   Reply With Quote
Old 06-08-2005   #2 (permalink)
Future RIII owners should perhaps be GRATEFUL to us, RIII pioneers and forum members, for the learning curve, ours and that of our dealers.
But they won't
[ This message was edited by: Jamie on 2005-06-08 11:45 ]
Jamie is offline   Reply With Quote
Old 06-08-2005   #3 (permalink)
I was not happy !
that sucks, seemed like triumph/the stealer just didn't want to pay for the problem search. good thing the 'owner' brought his bike in. otherwise, you would still get the run around. glad you're getting your problem solve.
cyclerider is offline   Reply With Quote
Old 06-08-2005   #4 (permalink)
Toystoretom's Avatar
This seems kind of curious that there doesn't appear to be any way to measure fuel pressure with the fuel tank on the bike and the engine running. I will have to look at the fuel rail next time I have the tank up. It could be that Triumph has an adaptor in their shop tool inventory that allows you to hook up a fuel pressure guage. The shop manual makes no mention of this. It does give a nominal fuel pressure of "3.0 Bar" which translates into ??? psi. Possibly there is a port or a Schrader type valve that you can attach a fuel pressure guage to....
Tomo
Triumph Rocket III
Toystoretom is offline   Reply With Quote
Old 06-08-2005   #5 (permalink)
3.0 bar = 43.5 psi
1 bar == 14.5 psi
HTH
Tom
tmiller11147 is offline   Reply With Quote
Old 06-09-2005   #6 (permalink)
Thanks Tom!!!!
(I always thought 1 bar = whiskey) :-D :-D
Tomo
Triumph Rocket III
Old 06-09-2005   #7 (permalink)
...any bar will do, I'm baring up right now. :-D good post cookie monster...
Here 1 minute, next minute........ SO GONE.................
http://smileys.smileycentral.com/cat/26/26_11_5.gif
nugget is offline   Reply With Quote
Fuel Pump crackerkorean Sprint Forum 10 09-21-2007 10:59 PM
'02 st fuel pump tojohn Sprint Forum 8 11-17-2006 10:24 AM
Help! Fuel Connector/Fuel Pump LeDude Speed Triple Forum 2 09-18-2006 09:58 PM
Fuel Pump MVP44 Sprint Forum 6 09-03-2006 11:56 AM
fuel pump and fuel injectors speedmerlau The Rocket Science Forum 5 11-01-2005 01:12 PM
