High Idle, backfiring, hesitation.... I'm lost
Hi guys. I lurk over on the Meriden section of the forum. I'm over here because I am trying to help a friend with his rocket 3. He asked me if I could help with his high idle/hesitation problem... so that brings me here.
I did some research before I began and did a 12 minute tune. After that I let the bike cool off and took it out about two hours later. The bike idles around 900-1000 rpm while in the drive way. I start off down the road and immediately hit a rough spot around 2300 rpm. it seems to smooth out until 3100rpm where it get rough again briefly and from there seems ok. If I close the throttle the bike does not drop below 2000 rpm. I pulled into the nearest parking lot and shut the bike off waited a few seconds and restarted it. RPM immediately jumped to 2000... shut the bike off again and wait. Restart and idle is ok. Take off out of the parking lot and immediately the idle is 2000 rpm. If I crack the throttle off idle (2000 rpm) it back fires some times from what seems like the left pipe.
I have read Tomo's thread on resetting the idle speed but it seems to be more for low idle condition than high. Can anyone point me in the right direction?
Thanks,
Bill
