BikeBanditMotorcycle.com
BikeBandit
Old 06-04-2005   #1 (permalink)
Would anyone have the complete adjustment procedure for the rocket?
Snakepit is offline   Reply With Quote
Old 06-04-2005   #2 (permalink)
Snakepit - after a couple of weeks on the bike (I suppose it had done about 1500 miles) I noticed that it had become harder and harder to find neutral or move from first to second. I concluded that the cable had stretched a little. I loosened the large nut nearest the lever and then turned the smaller nut so that the cable shortened. This solved the problem.
Old 06-04-2005   #3 (permalink)
snakepit,
what anddean said about with about 1/ 16" freeplay gap in lever crack
dragline708 is offline   Reply With Quote
Old 06-04-2005   #4 (permalink)
After a couple hundred miles I found the gearbox harder to find neutral. I took up the slack a little, and it helped but I do not want to put any pressure at all on a throwout bearing or anything.
Just wondering....there must be a more thorough clutch adjustment in the service manual.
Old 06-04-2005   #5 (permalink)
S.P. send me yr. email address (I'm at anddean@gmail.com) and I'll email you the page from the workshop manual - but it doesn't say much more than the above ...
Clutch adjustment? argie Classic, Vintage & Veteran 3 01-23-2008 02:59 PM
Clutch Adjustment cmb13 Hinckley Classic Triples 2 10-08-2007 02:46 AM
Clutch adjustment johnsime Twins Technical Talk 4 10-07-2006 07:04 PM
clutch adjustment tinhead Classic, Vintage & Veteran 7 05-30-2006 09:07 PM
Clutch adjustment Hinckley Classic Triples 10 06-18-2004 03:18 AM
