Hi Steve,
I have adjusted my Classic Rocket handlebars. I had them bent some. A little bit more pull back and a little bit more angle at the grip bend. I also have a set of Rivco rizers, they lift and set the bars back some. I am going to replace my brake lines and run two seperate lines off the front master brake cylinder. Might install them tomorrow night. Getting the Goodridge brand of brake lines and fittings.
My handle bars have a spread of 32" center to center at the end of the rubber grip, not including the grip tip. I thought the brake line was to snug in a tight turn. So I am replacing them.
odie
Reason: removed quote that was both needless and damaged
