Edge Brackets Quick Release Detachable saddlebag system - Triumph Forum: Triumph Rat Motorcycle Forums
Honda Powersports Motorcycle.comNew Bonneville
Old 03-28-2009, 10:44 AM   #1 (permalink)
Favourite Bike: RCIII
Mudcat's Avatar
I'm looking to pick some up, has anyone tried a set of these? Can anyone give me a review?
Thanks
Link--
http://www.edgeleather.com/Triumph-M...1-Present.html
Mudcat is offline   Reply With Quote
Old 03-28-2009, 06:15 PM   #2 (permalink)
Favourite Bike: 2005 Rocket III
Other Motorcycle: 2001 Roadking Classic
Extra Motorcycle: 1999 Busa
JMO..I got the K-Drive Bags,you can take them off and carry them in like two suit-cases. When you don't need them the bracket blends in nicely without the bags on.
http://www.newr3.com/html/accessories.html
http://www.vartex.be/Click-lock-saddlebags-Triumph.html
TRIIICK is offline   Reply With Quote
Old 03-29-2009, 12:07 AM   #3 (permalink)
Favourite Bike: 05 Speed Four
snuffcityrider's Avatar
Other Motorcycle: 2010 Gold Wing
I have the Easy brackets and they mount the same exact way. I like them alot. You hardly notice the studs when the bags are off and the lock works very well.
snuffcityrider is offline   Reply With Quote
Old 03-29-2009, 12:09 AM   #4 (permalink)
bags off
Old 03-29-2009, 12:07 PM   #5 (permalink)
Favourite Bike: 08 Rocket 3
KingOfFleece's Avatar
Other Motorcycle: Bonneville 2009
I just installed the EDGE 103's with EZ Brackets. Great set-up. 2nd go around with EZ's-a good product all in all.
KingOfFleece is offline   Reply With Quote
Old 03-29-2009, 04:35 PM   #6 (permalink)
My Triumph bags with Easy Brackets were stolen. I was looking at the Edge 103 but got the K-Drive bags instead. They're really nice.
If you want to get bags with detachable brackets, get the Easy Brackets. The Edge brackets look like Ghost Brackets, which means they're adjustable, which isn't good. The Easy Brackets aren't adjustable, are made specially for the Rocket, and fit perfectly.
dougl is offline   Reply With Quote
Old 04-08-2009, 10:49 AM   #7 (permalink)
Other Motorcycle: '92 FLHS
Snuff,
What bags are those? I'm looking into the K-Drive bags but putting EasyBrackets on them, so am interested in how to do that without screwing up the bags.
Mike
mikemartin88 is offline   Reply With Quote
Old 04-08-2009, 12:23 PM   #8 (permalink)
The K-Drive bags come with mounting hardware on the bags. I think this is removable. The mounting bracket for the fender is pretty inobtrusive and the Easy Brackets would add weight to the bags.
Old 04-08-2009, 01:04 PM   #9 (permalink)
Diego's Avatar
Everyone... please do NOT use the Quote button as a substitute for Post Reply. It is wasteful of bandwidth, and is quite unnecessary when you're replying to a short message that will be sitting right above your own for everyone to see anyway!
Quote is many for when you're replying to a message that is not the last one in the thread, and you want to avoid confusing the reader.
It's also OK to use Quote if the last message is a very long one and you only wish to respond to one particular point--but be sure to carefully edit out all but the point you wish to address! Otherwise, it does nothing to help the potential confusion.
Thanks.
John
Old 04-08-2009, 11:04 PM   #10 (permalink)
http://www.leatherneckjims.com/shop/...67724885bbb38a
This is where I got them, they are the "Bad Lands" model. You just put the brackets on the bike, hold the bag where you want it, mark the back with a Sharpie pen and then transpose on the other side. If you have stock pipes be sure to do the right side first since it has to be higher due to having two pipes on that side.
Interest in Quick-Release Saddlebag Mounts? bonniesaltrat Twins Technical Talk 8 01-10-2007 02:07 AM
Saddlebag brackets wonderdog Twins Technical Talk 1 12-24-2006 07:10 AM
Saddlebag brackets Sixmil Twins Talk 21 02-12-2006 09:10 AM
Saddlebag brackets Sixmil Maintenance & Workshop Talk 4 02-02-2006 12:26 PM
Who uses saddlebag brackets? UJMrider Hinckley Classic Triples 18 04-30-2005 09:56 PM
