correct antifreeze for 05 Rocket 3 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 03-17-2009, 08:13 PM   #1 (permalink)
Time to change out the blue mobil antifreeze. I can not find it in the USA. So what is the equivalent replacement coolant ?
40786 is offline   Reply With Quote
Old 03-17-2009, 08:40 PM   #2 (permalink)
Diego's Avatar
Any aluminum-safe glycol based antifreeze should be just fine.
John
Old 03-17-2009, 08:48 PM   #3 (permalink)
Thanks , I have the Factory manual and had bought some ICE for it but have not switched yet. I had read some problems with corrosion issues and was hesitant to change anything until I had more info.
Old 03-17-2009, 11:18 PM   #4 (permalink)
Favourite Bike: 2005 Rocket III
Other Motorcycle: 2001 Roadking Classic
Extra Motorcycle: 1999 Busa
This is one bridge i haven't crossed yet with the Rocket, keep us posted on the results. I haven't even attempted to read up on how to change it. A fellow Rocket owner told me he buys his anti-freeze from Amsoil.??
http://www.amsoil.com/storefront/ant.aspx
TRIIICK is offline   Reply With Quote
Old 03-20-2009, 08:44 PM   #5 (permalink)
I was under the impression that the stock coolant was nothing more than blue-tinted, inorganic ethylene glycol that needed to be changed every three years. Is any of that true?
My 05 Rocket's water pump started leaking about 6 months ago. I replaced the O-ring and it sealed right up. I ended up refilling the system with G05 coolant. I can't recall now all the reasons why I decided to run that coolant, but I knew that I wanted an extended drain coolant that was compatible with a system that used to run normal inorganic ethylene glycol. I'm not saying that G05 is compatible with inorganic ethylene glycol, but as I recall G05 still has some silicates which are normally incompatible with organic coolants due to the organic coolant's acidic nature, but since G05 is pH neutral it has no affect on the silicates. So from what I gathered, the silicate "plating" from the old coolant or the little bit of old coolant that didn't get drained shouldn't reduce the effectiveness or longevity of the G05 coolant.
Barak is offline   Reply With Quote
Old 03-20-2009, 08:57 PM   #6 (permalink)
Diego's Avatar
How can ethylene glycol be "inorganic"?
John
Old 03-20-2009, 11:00 PM   #7 (permalink)
if it doesnt have carbon in it it is inorganic.. dont know about the anti freeze but that is the chemical definition
travelguy is offline   Reply With Quote
Old 03-21-2009, 02:55 AM   #8 (permalink)
Diego's Avatar
Yeah, I know the chemical definition of inorganic. That's how come I'm wondering how ethylene glycol can ever be inorganic.
John
Old 03-21-2009, 10:13 AM   #9 (permalink)
A bad reaction on the part of inorganic and organic
http://www.youtube.com/watch?v=jeVF-VZKckk
Old 03-21-2009, 01:22 PM   #10 (permalink)
Lee
Multi-Iron Butt Moderator
Favourite Bike: Triumph RIII Graphite
Lee's Avatar
Other Motorcycle: Honda Goldwing 2012 Red
Extra Motorcycle: Is it really ever extra..
It is not organic.......
ETHYLENE GLYCOL
1. Product Identification
Synonyms: 1,2-Ethanediol; glycol; 1,2-Dihydroxyethane; Ethylene Alcohol; Ethulene Dihydrate
CAS No.: 107-21-1
Molecular Weight: 62.07
Chemical Formula: CH2OHCH2OH
Product Codes:
J.T. Baker: 5387, 5845, 9140, 9298, 9300, 9346, 9356, L715
Mallinckrodt: 5001, 5037
2. Composition/Information on Ingredients
Ingredient CAS No Percent Hazardous 3. Hazards IdentificationEmergency Overview
WARNING! HARMFUL OR FATAL IF SWALLOWED. HARMFUL IF INHALED OR ABSORBED THROUGH SKIN. MAY CAUSE ALLERGIC SKIN REACTION. MAY CAUSE IRRITATION TO SKIN, EYES, AND RESPIRATORY TRACT. AFFECTS CENTRAL NERVOUS SYSTEM.
SAF-T-DATA(tm) Ratings (Provided here for your convenience)
Health Rating: 2 - Moderate (Life)
Flammability Rating: 1 - Slight
Reactivity Rating: 1 - Slight
Contact Rating: 3 - Severe (Life)
Lab Protective Equip: GOGGLES & SHIELD; LAB COAT & APRON; VENT HOOD; PROPER GLOVES
Storage Color Code: Green (General Storage)
Potential Health Effects
Inhalation:
Vapor inhalation is generally not a problem unless heated or misted. Exposure to vapors over an extended time period has caused throat irritation and headache. May cause nausea, vomiting, dizziness and drowsiness. Pulmonary edema and central nervous system depression may also develop. When heated or misted, has produced rapid, involuntary eye movement and coma.
Ingestion:
Initial symptoms in massive dosage parallel alcohol intoxication, progressing to CNS depression, vomiting, headache, rapid respiratory and heart rate, lowered blood pressure, stupor, collapse, and unconsciousness with convulsions. Death from respiratory arrest or cardiovascular collapse may follow. Lethal dose in humans: 100 ml (3-4 ounces).
Skin Contact:
Minor skin irritation and penetration may occur.
Eye Contact:
Splashes may cause irritation, pain, eye damage.
Chronic Exposure:
Repeated small exposures by any route can cause severe kidney problems. Brain damage may also occur. Skin allergy can develop. May damage the developing fetus.
Aggravation of Pre-existing Conditions:
Persons with pre-existing skin disorders, eye problems, or impaired liver, kidney, or respiratory function may be more susceptible to the effects of this substance.
Four Iron Butt Rides Todate....Will Be Working On Longer Ones In The Upcoming Year...Jersey Born and Raised........Texas run 1000 in 24 hours in April 2012
Lee is offline   Reply With Quote
Where did my antifreeze go? Maintenance & Workshop Talk 11 07-17-2007 10:28 PM
Antifreeze Bluetiger901 Maintenance & Workshop Talk 2 03-18-2007 11:40 PM
antifreeze top-off white06S3 Speed Triple Forum 7 09-25-2006 03:35 PM
Antifreeze? SaddleTramp Sprint Forum 5 10-27-2005 03:08 PM
Antifreeze BillBo Hinckley Classic Triples 21 06-13-2005 04:18 PM
