Rocket problems during Bike Week - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Old 03-11-2009, 01:47 PM   #1 (permalink)
My '06 Classic developed problems the last couple of days of Bike Week. I rode about 25 miles north of Daytona to a resturant and all was fine, but when I went to leave it started to miss real bad and wouldn't run on all three unless I got over 3k rpm. I made a run for the interstate to try to reach the Triumph dealer and as soon as I got on I-95 the limp mode kicked in and it ran fine all the way to the dealer. I shut it off and when I re-started it it was missing like before. The Triumph tech was at the racetrack all day Friday and Saturday so no one looked at it. It's back in Ohio now and as soon as it warms up a little I'm going to have a look myself before I take it to my local dealer. Any thoughts guys?
P.S. The bike has 26k miles on it.
Mike
06 classic
Wimpy is offline   Reply With Quote
Old 03-11-2009, 03:55 PM   #2 (permalink)
Diego's Avatar
Well, if it ran OK in limp-home mode, that means your fuel system is good, your injectors and ignitors are (probably) OK, and the ECU is getting commands to them just fine. That leaves one or more sensors as the likely culprit. Unless you have the means to diagnose and/or replace those, I suspect you'll probably need to leave it to your mechanic.
John
Old 03-13-2009, 09:40 AM   #3 (permalink)
Favourite Bike: ROCKET 3
Wimpy,
I had a similar problem last year with my '07.
Turned out to be a coil wire on one of the coils.
It looked hooked up tight, it was screwed on tightly, but internally, it had slipped out.
Had you take it to the dealer to get it sorted out.
Good luck,
skip
xhdskip is offline   Reply With Quote
Old 03-13-2009, 09:52 AM   #4 (permalink)
Thanks for the replies guys. On a lighter note I was driving home from Daytona on Sunday and was about 15 miles from Atlanta on I-75 in stop and go Nascar traffic when I saw a pick-up pulling one of the Triumph 5th wheel trailers broke down on the side of the road. I pulled over to see if I could be of help and the guy said it was missing and cutting out real bad like there was water in the fuel and I said that's funny I have a Rocket in the trailer with the same symptons! We both had a good laugh!
Mike
06 classic
Old 03-15-2009, 01:32 PM   #5 (permalink)
Update: It finally reached 50 deg. today and I lifted the tank and there is a "T" connection for vacuum lines and one was off, re-connected it and all was fine. Good day to buy a lottery ticket! Mike
Mike
06 classic
Rocket III Diff problems? fog The Rocket Science Forum 42 12-21-2009 09:52 PM
Rocket 3 gearbox problems hanseman The Rocket Science Forum 9 04-08-2009 08:39 PM
Rocket problems out of hand? dazco The Rocket Science Forum 38 07-25-2007 07:16 PM
A week on the bike sweatmachine Twins Talk 22 04-08-2006 02:21 PM
WHO IS GOING TO BIKE WEEK? TRISPEED Speed Triple Forum 12 12-13-2005 01:39 PM
