High compression pistons, more aggressive valve lift and timing, larger fuel injectors and an actual free flowing header to replace the exhaust "log" manifold and a stronger clutch would make 200 HP easily reachable.
The RIII motor is really in a low state of tune as it comes right now. As powerful as it is, there's still alot more horsepower available. Our compression ratio is only 8 to 1, or 8.5 to 1.
What we really need is a different ratios in the transmission. or a higher final drive ratio..
Dave Arnold
'04 Rocket III
'00 Trophy 1200
La Vernia, TX
