Rocket Three spray can noise! - Triumph Forum: Triumph Rat Motorcycle Forums
Old 02-23-2009, 09:06 PM   #1 (permalink)
My 05 R3 just started the ticking noise that sounds like a lifter rattle. How do I adjust the self adjusting cam tensioner? Do I need to drain the oil to do this? Thanks
riknew is offline   Reply With Quote
Old 02-23-2009, 09:38 PM   #2 (permalink)
Favourite Bike: 2006 Rocket III Classic
Pig9r's Avatar
It's self adjusting, hence the name. However, it is one of the many parts that are replaced in Triumph's upgrade kit for the Rocket III, which sounds like you will be a recipient of. Contact your nearest dealer and tell them what you have. Triumph should take care of it all whether or not you are in warranty.
BTW, don't take the adjuster out without the cam cover and front covers off of the engine. The cam chain will likely fall off of the crank gear or one of the cam gears.
Paint spray Ninjaboy Triumph SuperSports 1 05-19-2007 10:24 AM
Dyno on the spray! bonnieblackinfl Twins Technical Talk 6 03-22-2007 01:43 AM
Wonder spray -- WD40?? toocaffeinated Twins Talk 8 08-16-2006 08:27 PM
Scandinavian noise for the Rocket Tumbleweed The Rocket Science Forum 1 07-08-2005 08:10 AM
