Rivco ignition kit connectors wrong.... - Triumph Forum: Triumph Rat Motorcycle Forums
Old 02-16-2009, 03:46 PM   #1 (permalink)
Favourite Bike: 2005 Rocket III
Bobby K's Avatar
Other Motorcycle: 1973 Triumph Tiger
Extra Motorcycle: 1995 Triumph Thunderbird
I just attempted to install the ignition switch relocation kit from Rivco. All was well until I went to plug in the extension harness. Problem is the connectors on the Rivco piece are different than what my 2005 Rocket has. Apparently when I had the "upgrade kit" installed last fall, a redesigned ignition switch connector was spliced in by the mechanic, so the Rivco connectors no longer work. I have contacted the Triumph dealer I bought the Rivco kit from, and sent an e-mail to Rivco, but I suspect it's going to be my problem to fix with a soldering iron. Just a warning to all....
Bobby K is offline   Reply With Quote
wrong thing at wrong time fugitive Biker Hang-Out 9 09-16-2008 09:03 PM
Rivco ignition switch install? TBAbob The Rocket Science Forum 11 06-06-2007 02:25 AM
ignition switch relocation by rivco kingpinnh The Rocket Science Forum 8 04-23-2007 09:44 PM
Wrong primary-case = wrong timing happyray Classic, Vintage & Veteran 3 04-05-2007 11:27 AM
remove ignition barrel from ignition switch? kanoa Classic, Vintage & Veteran 3 07-13-2006 01:50 PM
