Radiator Cooling Fan - Triumph Forum: Triumph Rat Motorcycle Forums
Old 01-22-2009, 09:23 PM   #1 (permalink)
Favourite Bike: 06 Scrambler 900
Other Motorcycle: Rocket 3 Classic "08"
It seems that sometimes the cooling fan starts up about the time I want to rurn off the Rocket. Should I just turn off the engine or let the fan cycle and the when the fan shuts off turn off the engine ?
odie
odie is offline   Reply With Quote
Old 01-22-2009, 11:00 PM   #2 (permalink)
Diego's Avatar
You can go ahead and switch the engine off whenever you are ready. If the water temperature is hot enough to be a concern, the ECU will keep the fan powered up for a while anyway. If the temperature is not high enough to pose a problem, then it won't stay on.
John
Old 01-23-2009, 12:46 AM   #3 (permalink)
Thanks John
Cooling the 07 R/R Triple Ripple Sprint Forum 3 06-13-2008 07:08 PM
Cooling Fan On A Lot? dblhelx Speed Triple Forum 12 07-03-2007 01:59 AM
Radiator covers-cooling amberale Speed Triple Forum 10 07-16-2006 01:43 AM
S4 Cooling fan BigPappa Triumph SuperSports 6 01-20-2006 02:55 PM
Cooling Fan Hinckley Classic Triples 6 04-27-2004 03:06 PM
