Originally Posted by bobmielke
If the shield that comes stock with the bike proves to be too short it wouldn't be a problem for me to use the hardware, saving the original shield for emergencies or to put back on the bike should I decide to sell/trade the bike someday.
I thought I heard that Triumph had a taller screen for the Touring. Clearview recommends that the height of the screen should allow you to look over the top of it and see the road 50 ft in front of the bike. The air flow still goes over your helmet. The reason I got a Clearview is because it's wider, especially at the bottom and this reduces buffeting from air coming from below.
Is the buffeting issue with the Touring the same as with the standard? While the radiator contributes to this, the tank has a different shape, so the problem might not be the same. If it is, however, the Clearview screen needs to be wider than the stock.
