| The Rocket Science Forum 2300cc's of Propulsion |
12-15-2008, 03:48 PM
Radiator problems
I noticed with my 2005 rocket III that after the bike warms up at the lower part of the radiator it starts to smoke a little but there are no leaks coming out on the ground etc does this mean my radiator is bad? its on the radiator itself not underneath it
12-15-2008, 06:00 PM
Formula Extreme Favourite Bike: 2010 Thunderbird
Posts: 645 Other Motorcycle: '07 R3, '09 & '69 Bonnie Extra Motorcycle: 69 BSA, 74 Norton, + more
Smoke (steam) is an indication it's leaking coolant. You should be able to smell it too. Check the threaded inserts that attach the shroud and mounts. I had one pop out on my '07. Triumph replaced the radiator under warranty. Good thing 'cause it was $589.00
I may be old, but I'm not slow...
12-15-2008, 06:08 PM
Formula Extreme Favourite Bike: Rocket III
Best guess - condensation collected on the radiator and when heated burns off. I assume this happens at first start up and doesn't reoccur later. Fluids are topped off, tight cap, no leaks on the floor - right?
12-15-2008, 08:01 PM
re radiator
you can smell the antifreeze smell so there must be a leak is it better to just get another one or to get it repaired?
12-15-2008, 08:03 PM
ill check that I can definitly smell the antifreeze smell bike isnt uner warrenty so i may have to just bite the bullet and replace the radiator.
is it hard to replace? ive replaced car radiators
12-15-2008, 08:10 PM
Because mine is under warranty I let them do everything, including picking the bike up and hauling it into their shop. I'd just try some radiator stop leak first since you are out of warranty. I once had a car I uses stop leak on the rad. and it worked for several years. Removing and replacing the radiator can't be very difficult. Make sure you remove the tiny screw in the cap before attempting to remove the cap.
12-15-2008, 08:37 PM
Formula Extreme Favourite Bike: 2006 Rocket III Classic
The radiator is pretty easy to remove.
I would take the radiator to a local repair shop and see with they can do before you dump any barrs leaks etc into the coolant system.
12-16-2008, 12:33 PM
250 Grand Prix Favourite Bike: 08 triumph R3T blue/blue
Posts: 136 Other Motorcycle: 07 triumph america blue/w Extra Motorcycle: n/a;explorer sport truck
Repair or replace the radiator..I have never had success with stop leak/bars leak,etc..It only pluggeed up the water jets in the engine causing valve issues and hot spots..$600 at the max will be cheap compared to a rebuild..also your dealer may be able to get Triumph to warranty the Radiator unless you dropped it and caused damage.
12-17-2008, 03:59 AM
Not all radiator stop leaks are equal.
Some work much better than others and aren't thick like they all used to be.
A new rad. is prefered but not everyone is prepared to shell out $600.00, especially in this poor economy and at Christmas time...
12-17-2008, 04:46 PM
I agree with Pig9r about not putting any stop leak in the radiator if you think it can be fixed. The radiator is right there in the open. It's not hard to remove, and a competent radiator shop should be able to fix it.
IF.. you are in bind, though, and you don't intend to fix that radiator.. Oat Meal will seal a radiator leak..
Dave Arnold
'04 Rocket III
'00 Trophy 1200
La Vernia, TX
