Handlebar Diameter & Replacement Thread - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!New BonnevilleSportbikeTrackGear
Old 11-19-2008, 10:31 PM   #1 (permalink)
So, now that I've been riding a few days since I got my bike. I notice that I'm more bent forward than I remember while test riding. I remember that dealer mentioned they had replaced the stock handlebars on the demo bike. Since I didn't buy the bike from that dealer, I feel embarrassed asking. I'm guessing though that the handlebar might be the issue. Does anyone know options for replacing the stock handlebar?
triumphvkk is offline   Reply With Quote
Old 11-20-2008, 01:13 AM   #2 (permalink)
Favourite Bike: '08 Street Triple
If you do a search of "handlebars" on this site...you'll probably find any info your looking for. There are LOTS of existing threads on this, covering just about everything from A to Z.
Ken M1 is offline   Reply With Quote
Old 12-08-2008, 02:03 AM   #3 (permalink)
what is the diameter of the standard striple handlebar?
Anyone know?
Old 12-08-2008, 12:59 PM   #4 (permalink)
Diego's Avatar
By carpenter's ruler, it's 7/8 of an inch OD... or whatever the nearest metric equivalent would be.
John
Old 12-09-2008, 12:26 AM   #5 (permalink)
"Standard" = 22mm. "Fatbar" (such as R bar) = 28mm.
Old 03-25-2009, 01:27 AM   #6 (permalink)
Lookin To Get New Bars
Just picked up my new 2009 street triple over the weekend and have to say this bike is amazing. i was lookin to get new handle bars that are a little wider and taller, any suggestions? if i go taller do i have to change out cables?
tearuridolsdown is offline   Reply With Quote
Old 03-26-2009, 10:49 PM   #7 (permalink)
Although this topic has been covered quite extensively in previous posts.... A short answer is, the stock cable have VERY little slack in them and won't allow much handlebar rise without extending/replacing cables. For bars, themselves, check out: Renthal, Magura, Rizoma, Protaper, Easton, Lsl/Spiegler, Etc. Hope that helps you get started.
Old 03-27-2009, 01:38 PM   #8 (permalink)
Im gonna get Easton bars either CR high or Mid. im not gonna get clamps that are higher just the bars will be slightly higher. i was lookin to see if anyone has went to those bars with out changing cables.
Old 04-02-2009, 10:02 PM   #9 (permalink)
standard Street triple Handlebar spec
Anyone know the rise, height, pullback etc specs for the standard striple handlebar? The triumph website only has the width which is 29.8. I want to get a higher bar but don't know the current ones specs. thanks
Old 07-03-2009, 12:52 PM   #10 (permalink)
Favourite Bike: Don't make me choose!
jtusega's Avatar
Other Motorcycle: 2009 Street Triple R
Extra Motorcycle: 2007 America
Handlebar Diameter and Part Replacement
I'm trying to find an OEM replacement clutch lever bracket clamp for my 2009 Street Triple R. I looked on bike bandit but the only brackets I see are for the Street Triple (Bike Bandit #7532684-001) and don't show the mounting post for the mirrors. Are the Street R handlebars the same diameter as the Speed Triples? I ask because the Speed Triple's clutch lever bracket clamp (Bike Bandit #5568434-001) does depict the mirror mounting post. Thanks for the help guys. And as some free wisdom for y'all, never do rushed maintenance. You end up buying new parts :-p
JT
"Every time I start thinking the world is all bad, then I start seeing some people out having a good time on motorcycles, and it makes me take another look."
~Steve McQueen
jtusega is offline   Reply With Quote
Handlebar Diameter for 73 T140 LukeSmith1985 Classic, Vintage & Veteran 4 01-31-2009 12:50 PM
Handlebar Diameter... sharp21 Twins Talk 3 01-17-2009 04:33 PM
Handlebar Diameter patrol21 Hinckley Classic Triples 5 01-11-2008 02:56 PM
Handlebar diameter? petjamrut Twins Technical Talk 2 05-05-2007 05:50 AM
Handlebar diameter Bert Twins Talk 4 11-18-2006 10:26 PM
