Flyscreen and bellypan installing ? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-18-2008, 10:45 AM   #1 (permalink)
Hello,
I will be getting my flyscreen and bellypan this weekend and if the weather is OK I will ride my bike to pick them up. I am planning to install them myself before riding back home, so I'd greatly appreciate it if someone here could tell me what tools I will need to take.
Neanderthal
Neanderthal is offline   Reply With Quote
Old 11-19-2008, 03:22 PM   #2 (permalink)
Favourite Bike: My T-BIRD
Rob 93ZR-1's Avatar
Other Motorcycle: 2006 T-100 (Totalled)
I am in exactly the same boat. Please help us out.
Thanks!
Rob 93ZR-1 is offline   Reply With Quote
Old 11-19-2008, 03:38 PM   #3 (permalink)
Rob,
I posted this same question on a couple other ST3 boards and so far here is what I have:
7mm & 8mm sockets
small flat-head screwdriver
small phillips screwdriver
and various small allen-head wrenches
I plan to just take sockets from 6mm to 13mm and allen T-wrenches from 4mm to 10mm. Might take a pair of needle nose and regular pliers as well. And a small towel to sit things on.
Neanderthal
Old 11-20-2008, 03:41 AM   #4 (permalink)
Favourite Bike: All of them.
Shakey's Avatar
Other Motorcycle: Moto Guzzi California EV
If you're getting the visor don't forget a drill and the appropriate bits. Since you'll be at the dealer in the first place why not pay a few extra bucks and have them install the items while you have a cup of coffee? Mine were shipped to me so I installed it all at home. Surely you could work out a decent deal with the guys that sold them to you.
Ride safe and often.
Shakey is offline   Reply With Quote
Old 11-20-2008, 09:26 PM   #5 (permalink)
Favourite Bike: 2010 Rocket III Roadster
I took my striple to the dealer that I bought it from and they installed the bellypan, rear hugger and seat cowl all for FREE! Just talk to the guys and i'm sure they'll hook you up, especially if you bought the bike and the parts from them.
BRich is offline   Reply With Quote
Old 11-29-2008, 08:45 AM   #6 (permalink)
Djm
How did it go, Neanderthal? I am about to pick up my flyscreen and visor from the dealer this morning and install it...
I actually found a thread with pics on the Speed forum. I suppose the ST3 installation is more or less the same?
Djm is offline   Reply With Quote
Old 11-29-2008, 02:25 PM   #7 (permalink)
The weather ended up being too cold for the long ride so I just brought it home and installed it. Installation of the belly pan took about 10 minues tops and was straight-forward. There is a small plastic plug on the rh rear point that needs to unscrew out - that took me a little bit to figure out as I was trying to just pull it out. The instructions were not clear about that.
The flyscreen took about 25 minutes. I had to really pull hard on the instrument cluster backplate to get it off. The flyscreen to cluster mounting plate was a bit looser than wanted, so I used some tie-wrap to take out the slack on the mountin posts - you'll understand this when you see it. Triumph needs to re-visit this part of the design. My fix seems to work but the factory could do a better kob here.
You will need some metric allen wrenches in 6, 7, 8mm, a small flat-head screwdriver. Take the shortest allen wrenches you have as there is not much room to work around the cables when installing the flyscreen. You can tighten things up better when you get home.
BTW, my bellypan did not come with the stick-on heat shield patches outlined in the installation manual. I used some of that aluminun muffler tape as a temporary shield. I called the dealer Tuesday and they called Triumph USA - who said the shielding was not needed. I'd be interested to know if yours was packed.
Neanderthal
Old 11-29-2008, 02:38 PM   #8 (permalink)
Djm
Ah...I had the same issue with the little plastic screws when installing my rear wheel hugger...I agree the instructions should have been more clear.
I actually just came in from installing my flyscreen. I agree that the back plate to instrument cluster is a bit looser than I would like. It seems as though a gasket like on the original instrument cluster back plate would have helped seal that small gap. When my visor comes in and I install it to the flyscreen, I am going to consider trying your method of making a better fit.
Dan
Old 11-30-2008, 01:52 AM   #9 (permalink)
Sorry I didn't get a chance to post this photo before you got started. As cheesy an idea as it is, it actually works pretty darn well. I just took a couple of 2" long sections of bread ties and wound them tightly into the gaps, then trimmed them.
Nice ST3 you got there!
Neanderthal
Old 12-06-2008, 04:55 AM   #10 (permalink)
Shakey's Avatar
Originally Posted by Neanderthal View Post
...BTW, my bellypan did not come with the stick-on heat shield patches outlined in the installation manual. I used some of that aluminun muffler tape as a temporary shield. I called the dealer Tuesday and they called Triumph USA - who said the shielding was not needed. I'd be interested to know if yours was packed.
Neanderthal
My belly pan didn't have the heat shield material shipped with it either. I went to my local dealer and he turned me on to some spare shielding he had laying around in the shop. Triumph may say you don't need it, but I feel better knowing there's something between my exhaust and the pan. It does get awfully hot when sitting at lights, or running hard in the summer.
Bellypan for a T3 Roden T3 Sport / Touring Forum 11 08-21-2008 10:34 PM
Bellypan help speedy3 Speed Triple Forum 3 02-11-2007 03:23 PM
bellypan NANDO Speed Triple Forum 0 05-29-2005 06:39 AM
bellypan? speedboy Speed Triple Forum 11 05-10-2005 02:18 PM
Installing a flyscreen on a TBS Hinckley Classic Triples 5 01-10-2004 07:13 PM
