Soupy's PerformanceMotorcycle.comTrident-Exhausts.comBritish Motorcycle GearCommonwealth MotorcyclesJardineProducts.comAnnitori Distributing
Closed Thread
Old 09-09-2008   #11 (permalink)
Newbie
Loose Chain
Just picked up my 09 Street Triple 12 days ago. I noticed the chain seemed loose but I looked in the owners manual and it was in spec. I looked throughout the book and could only find copyright 2007. Glad I just joined and read these posts.
RGV Trumpet is offline
Old 01-22-2009   #12 (permalink)
09 street and mine is just under an inch in slack
corpsedub is offline
Old 01-22-2009   #13 (permalink)
Diego's Avatar
Word of the correct setting must be getting around to dealers' shops.
John
Diego is offline
Old 01-23-2009   #14 (permalink)
i spoke too soon, i dont think i measured it right. i went back and measured it right in the middle, lifting in the middle with my thumb(which i did not doo before) and it was about 1 1/4 inch which pretty much the daytona spec. everyone should check thiers. it's a really easy adjustment to make if it's not in spec. just make sure to rotate the chain completly to make sure you dont have any spots that are too tight.
Old 07-03-2009   #15 (permalink)
Favourite Bike: 2010 Blazin' Orange St3R
'R' Chain Setting (Yes, I searched.)
So the owners manual says that the correct chain settings are 20-25mm on the Street and 35-40mm on the Daytona. My question is this:
On the Street Triple R, which setting do we use? Yes it's a Street, but it has the same geometry as the Daytona.
A little insight, por favor?
mcjonesy is offline
Old 07-04-2009   #16 (permalink)
Thanks for the help.
The owners manual supplement doesn't have the word "chain" anywhere in it, btw.
mcjonesy is offline
Old 07-04-2009   #17 (permalink)
Diego's Avatar
Operative words: it's a Street. The geometry is not visibly different from the Daytona anyway.
John
Diego is offline
Old 07-08-2009   #18 (permalink)
Favourite Bike: Street Triple R
2010 STriple R Manual says....
Daytona 24 - 30mm
Street Triple and STR 13 - 32mm
Humm........
Andybra is offline
Old 07-08-2009   #19 (permalink)
I can tell you from experience that at least on the 2009 Striple R 15-20mm is too tight. I accidentally got it that tight because I had the bike jacked up in the air and adjusted the chain with the rear wheel unloaded. I realized I had a problem within a few blocks however because you could feel the chain every time you hit a bump.
edit: I just checked the UK website and they haven't updated the downloadable manual yet. It's still the old 2008 one.
MacBandit is offline
Old 07-08-2009   #20 (permalink)
Diego's Avatar
Clearly a typo there, Andy. Don't follow that recommendation! There's no reason at this point to think the setting for the 2010 R is any different from the standard 2008 or '09.
John
Diego is offline
Closed Thread
This can't be correct, can it?! hassc Trophy 1 06-03-2008 09:50 AM
Setting correct sag – 07 Sprint shoen Sprint Forum 14 11-15-2007 12:29 PM
correct chain and sprockets? kc5deb Sprint Forum 8 10-11-2007 05:20 AM
Headlight : correct setting hkt100 Twins Technical Talk 15 08-08-2007 01:36 AM
Views on correct chain tension for Tiger ? JohnRimmer Tiger Chat 11 01-10-2006 05:59 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
