Motorcycle.com
Old 05-05-2008   #1 (permalink)
CRG bar end installation....
I gots a question for you who are more knowledgable than I. When installing the CRG bar ends, when you use the adapator what is the best way to knock out the weight in the middle of the bar, it looks to be glued in their good. Should i just use the old hammer and chisel to knock it loose?? Thanks in advance!
marker is offline   Reply With Quote
Old 05-05-2008   #2 (permalink)
Favorite Bike: Bonnie Black
terraplaneblues's Avatar
Other Motorcycle: Street Triple
Use a hack saw to cut the stud off the adapter. You can use the bolt from the stock bar-end to attach the adapter to the bar.
"When I die they'll say: He couldn't play s%@#, but he sure made it sound good" - Hound Dog Taylor
terraplaneblues is offline   Reply With Quote
Old 05-05-2008   #3 (permalink)
Favorite Bike: 1984 Kawasaki Ninja
srleadjb's Avatar
Extra Motorcycle: Ducati S4R
I bought the CRG adapters from British Customs but they arent cheap, $50! with shipping. I dont recommend taking out the center piece, it looks welded. You can take off the bar end that comes with the mirrors (you have to do this when you buy the adapters anyway ) Just use a washer on the outside of the mirror. So place the mirror up against the end of the bar, then place a washer (bigger than the opening obviously) and then use the bolt that came with original bar ends. It will tighten up nicely. On the throttle side, use a washer on both sides of the mirror (so one between the bar and mirror and one on the outside of the mirror.) If you want to go that extra step, paint the washers black first to match the mirrors. I used this technique until I received my adapters and it worked perfect.
srleadjb is offline   Reply With Quote
Old 05-05-2008   #4 (permalink)
Favorite Bike: All of them.
Shakey's Avatar
Other Motorcycle: Moto Guzzi California EV
+1. Works just fine. I just left about 3/8 inch of the adapter that inserts into the bar.
Ride safe and often.
Shakey is offline   Reply With Quote
Old 05-08-2008   #5 (permalink)
Follow-up question - what do you do with the posts that connected the old mirrors to the bars? Can you get a cap or something to cover the holes left behind, or can you remove them completely?
ridesallyride is offline   Reply With Quote
Old 05-08-2008   #6 (permalink)
Mirror hole plugs. They're available from Newbonneville.
Old 05-09-2008   #7 (permalink)
Shakey's Avatar
Are you talking about the Union Jack mirror plugs? If so are you using them on your bike? I like the looks of them, but would rather not spend $22 on something that won't fit. I'm liking these CRG bar end mirrors
Old 05-09-2008   #8 (permalink)
Yes. I'll be using them as soon as they arrive. They fit the speed triple and bonnie, so I'm confident they'll work. Hold off and I'll give a report when they arrive.
I love the CRG's too. I transfered them from my SV650. I also noticed that CRG just started making adapters for bars with plugs, like the Triumph.
Old 05-09-2008   #9 (permalink)
I've got the plugs - they fit perfect. High quality - a little expensive, but sometimes you gotta pay the price.
Mattrat is offline   Reply With Quote
Old 05-12-2008   #10 (permalink)
Shakey's Avatar
Here's a photo of my bike with the CRGs installed using modified CRG adapters, the original bar end screw and rubber bungs to fill the empty mirror mounts. Everything fits well and looks right IMHO.
my HID installation F4sSprintST Sprint Forum 15 04-24-2008 08:22 AM
Bar Installation DrewDesign007 Twins Technical Talk 7 10-08-2007 09:11 AM
TOR Installation Ben74 Twins Technical Talk 0 02-16-2007 10:02 PM
finally, 19T installation Boozer Twins Technical Talk 7 09-06-2006 03:13 AM
PC installation littlefield Speed Triple Forum 0 05-03-2006 08:35 AM
