2009 Street Triple R chain slack - Triumph Forum: Triumph Rat Motorcycle Forums
 4Likes
post #1 of 17 (permalink) Old 06-19-2017, 09:32 AM Thread Starter
Main Motorcycle: ST3R
jshish8's Avatar
I have read so many different values that I am thoroughly confused at this point. I am somewhat sure that the Streety has a lower slack value than the Daytona but that is about it. Anyone know what the true spec is? Is it better to be a bit too loose or a bit too tight?
| 2009 ST3R | ATGATT |
jshish8 is offline
post #2 of 17 (permalink) Old 06-19-2017, 12:12 PM
You're right there is a different slack between Daytona and ST3. I just adjusted slack yesterday so I have the page up on my phone. BE FOREWARNED THOUGH: this is from the 2015 manual. 2009 slack may be different. I downloaded the manual from Triumph on my phone. They may have earlier model manuals available online too.
Here is what is in my manual:
Chain Free-Movement Adjustment
Street Triple and Street Triple R
The vertical movement of the drive chain must be in the range 0.5-0.9 in (13 - 32 mm).
Daytona 675 and Daytona 675 R
The vertical movement of the drive chain must be in the range 1.1-1.5 in (28 - 38 mm).
jshish8 likes this.
Brent27 is offline
post #3 of 17 (permalink) Old 06-19-2017, 12:29 PM
Main Motorcycle: 2012 Street Triple R
dementedbrave's Avatar
i like about an inch of slack in mine, pretty standard for most sport bikes. 25 mm is about an inch. a too tight chain will do more damage than loose, unless it actually loose enough to jump teeth on the sprocket.
jshish8 likes this.
dementedbrave is offline
post #4 of 17 (permalink) Old 06-19-2017, 12:34 PM Thread Starter
jshish8's Avatar
By vertical movement do you pull down then up and measure from the same reference point? Thanks guys! I adjusted to right under 1 inch so I think I am good..
jshish8 is offline
post #5 of 17 (permalink) Old 06-19-2017, 01:51 PM
You're correct. As a summary, find a spot on the chain right in the middle of the two sprockets. From there, push the chain down and get a reading then push the chain up and get a reading. Difference between the two is the slack. Use one of the pins on the links as your measure points.
You should measure slack on the tightest part of the chain. Check the tension with your hands on multiple parts of the chain and pick the place the feels the tightest.
Lastly, though the manual is a bit vague, it looks like you're supposed to check chain tension with the wheels on the ground vs the rear being on a paddock stand.
Brent27 is offline
post #6 of 17 (permalink) Old 06-19-2017, 01:56 PM
Let me know if you need anymore help. I have easy access to the manual on my phone so I can copy instructions. Adjusting the chain isn't hard. The only real pain is the axle nut has a pretty high torque so it can be a struggle loosening it but is a breeze if you have a breaker bar/pipe.
jshish8 likes this.
Brent27 is offline
post #7 of 17 (permalink) Old 06-19-2017, 03:11 PM
Main Motorcycle: 2014 Street Triple R
Other Motorcycle: 2013 Kawasaki Ninja 300
That's what I gather as well, so I try to be near the upper limit of the range in the manual rather than the lower end of slack. One easy way for me to check if its getting a little on the loose side is to see how close chain is getting to the swingarm when I push it as far up as I can.
thousandwords is offline
post #8 of 17 (permalink) Old 06-19-2017, 03:51 PM Thread Starter
jshish8's Avatar
I think I am in the middle range of the slack if not slightly biased toward the loose end. What are symptoms if it is too tight?
jshish8 is offline
post #9 of 17 (permalink) Old 06-19-2017, 04:24 PM
I might be wrong but i don't think there is a real symptom to it, the major downside of a tight chain is as far as I understand it is this: as swingarm travels up it will tighten the chain; if chain is too tight, it will limit swingarm, hence rear suspension travel. That's why wheelie enthusiasts set chain slack looser than recommended, because when you wheelie the rear suspension supports all the bike's weight so it will be compressed a lot more than usual, so you need more chain slack to allow for the extra travel. Take this with a grain of salt as I am not into stunting, but this is what I rear here and there.
jshish8 likes this.
post #10 of 17 (permalink) Old 06-19-2017, 04:40 PM
I've heard the same as thousandwords, too loose you have drive line lash but too tight I haven't heard of any differences. Maybe a professional can tell the difference in how the rear suspension is acting.
I think if you're in the middle of the range you're fine. Over time the chain gets looser so you'll be moving towards the upper limit as you go along. I shoot for 3/4 of an inch and haven't had any issues. I had to adjust it for the first time in about 4,000 miles and it was at an inch even, so just outside the upper range.
Brent27 is offline
2018 Street Triple - Cleaning and Lubing Chain Methods Kremtok Street Triple Forum 1 06-12-2017 10:55 PM
Exhaust side valve clearances on daytona cams street triple thousandwords Street Triple Forum 1 01-16-2017 07:38 PM
Rather odd (read scary) past few days with my street triple thousandwords Street Triple Forum 4 06-16-2016 02:43 PM
2009 Street Triple Bgriff008 Street Triple Forum 0 09-29-2015 07:42 PM
