BikeBandit
Old 04-14-2008   #1 (permalink)
summer storage prep
I have a question about storage preparation for the Striple. I'm storing my bike in a self-storage unit while I take a trip from June thru August. The storage unit has a concrete floor and is located on the central coast of California so the temperature will probably range from high 50's to high 80's. All the info I could find on motorcycle storage is for cold weather prep. However, in my case temperature is not an issue but time is. Do I still need to do the following?
1. Full tank of fuel with stabilizer
2. Fresh oil (I got it changed 300 miles ago - should I get it changed again?)
3. Keep tires off the floor or rotated to prevent flat spots
4. Battery charger
5. Coat the body in some kind of oil/lube to prevent corrosion
Are all of these steps required? What else should I do? Is there any safe way to store the bike with an empty (or almost empty) fuel tank? Storing it with a full tank could be dangerous.
Any advice is appreciated. Thanks.
Striple is offline   Reply With Quote
Old 04-14-2008   #2 (permalink)
Newbie
Your in cali, your fine. Just unhook the battery. The Stabile stuff is good but emptying the tank all the way is the best, flushes all the fuel from the lines and injectors.
StreetNipple is offline   Reply With Quote
Old 04-14-2008   #3 (permalink)
Diego's Avatar
Three months without a charge is too long for any motorcycle battery. It will greatly shorten the life. DON'T use a conventional charger, though, especially if you're going to leave it plugged in that whole time! Use a battery tender that goes to float mode (not the same thing as trickle charge) when the battery is topped up.
Running the tank dry--not the greatest idea for a fuel injected bike, and even less so where a catalytic converter is involved. Use fuel stabilizer and run the bike enough to get stabilized fuel to the injectors. That'll be fine for three months. Drain the tank by means of pump or siphon if you don't want to leave fuel in it, but don't run it dry.
Oil change--that's a little tougher call. Three hundred miles since the last change isn't a lot, but in that short distance the clock has started running on the acid-neutralizing additives in the oil, and it has already taken on some moisture and other assorted combustion byproducts. If it were me, I'd err on the conservative side and change it again, but that's up to you; opinions may vary quite a bit on this.
As for other prep, winter and summer storage are not that different. Whether you should coat anything or not will depend on your humidity level. (Oil would not be my choice of a preservative, though.) If humidity IS a factor, then also tie or tape a plastic bag over the silencers. Triumph recommends a few drops of oil in each cylinder before storage, too.
John
Old 04-15-2008   #4 (permalink)
Favorite Bike: All of them.
Shakey's Avatar
Other Motorcycle: Moto Guzzi California EV
Everything with the exception of coating the surfaces with oil should work. A battery tender is a must for that length of time. How far from the ocean is the mini storage? Try to stay off of the coast proper to avoid the ocean air. I generally rent a temperature controlled unit for my collector car and bikes during the off season. A breathable cover helps keep the dust off your finish and don't empty the gas tank. Fuel stabilizer works just fine. Add the stabilizer according to instructions, top off the tank and run for 5 minutes to circulate the additive. I've never had a problem with my bikes for a month, or more at a time. Too bad you can't take it with you.
Ride safe and often.
Shakey is offline   Reply With Quote
Old 04-15-2008   #5 (permalink)
Thanks for the advice, guys.
Paint Prep Help oregonthruxton Twins Technical Talk 10 02-10-2008 05:34 PM
what's in the bike prep for a track day? sodapop Sprint Forum 6 07-30-2007 10:20 AM
Header Prep for BBQ Paint TRYMPH Twins Technical Talk 4 06-20-2007 10:17 PM
BIG Summer prep for laid up TT600 CliveTT600 Triumph SuperSports 3 04-07-2007 06:37 AM
Winter Prep Warning macamx Twins Talk 0 10-26-2005 08:16 AM
