Yes. Taping the seam using black electic tape would be same effect (although a little shiny...perhaps a flatter black, or grey would be better). This would just be short term though, as tape will not weather well. Electric tape does not like water. It will leave gluey residue around the edges of tape when exposed to wet. Perhaps if you used a flat black VINYL tape....NOW you're talkin! That way you could remove it later. I'm not sure the seam is smooth enough though. Tape requires a smooth surface or it will expand and "bubble" where not adhesed, where as paint is not a problem (as to shape).
