The Rear Shock Upgrade Thread - Page 7 - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismNew BonnevilleSportbikeTrackGearMotorcycle.com Classifieds!
Old 02-11-2009, 02:22 AM   #61 (permalink)
After racking up 2000+ miles I think Im going to install the Daytona shock that has been sitting in a box.
I'm 155lbs and may ride a passenger down the line. Am I going to regret not swapping the spring to a 500lb rate?
PsychBiker is offline   Reply With Quote
Old 04-30-2009, 06:03 PM   #62 (permalink)
Is the R shock and Spring identical to Daytona?
Can anyone confirm if the R shock and Spring are identical to that found on the Daytona?
Same valving and spring rate?
wobblyas is offline   Reply With Quote
Old 05-16-2009, 04:48 PM   #63 (permalink)
I was in a shop this past week and was talking to the parts manager about the rear shocks on the Striple vs. the Daytona. the part numbers are different between the two parts, but he had talked to someone at Triumph at one point and was told that the springs are definitly different rates.
He didn't know (the PM) if the valving was different. I've read in some reviews that it was, and others said it was the same. go figure. I'm guessing that it's close enough to not matter.
I am probably picking up a new Street Triple R next week, and will probably post the rear shock for sale in the classifieds or on ebay shortly after that (if there is a Penske or Ohlins for the R). I'm assuming that might be a nice upgrade for a standard Street Triple?
SpeedyR is offline   Reply With Quote
Old 05-21-2009, 07:24 PM   #64 (permalink)
Favourite Bike: ST675
Other Motorcycle: SV650
Extra Motorcycle: GasGas Pro 300
Originally Posted by AaronP220R View Post
I'm 6'5, 275lbs (I know, I know). A friend of mine who's big into racing and the whole bike thing told me that my bike is probably WAY undersprung for my weight and size and I should look into upgrading the shocks and springs with something more customized to my weight.
FWIW, check out what the guy in the video in this thread has to say about the sag for heavier guys:
http://www.triumph675.net/forum/showthread.php?t=29740
It’s just, the two guys I’ve been riding with lately are riding a SV650 (I know it’s a lesser bike)
I wouldn't go that far...I own both bikes and with relatively inexpensive/easy modifications front and rear, my SV feels more composed on bumpy roads than my Street. I love my Street, but should a bike that inspires confidence be called "lesser?" They are both good engines, just different.
pretzel is offline   Reply With Quote
Old 05-21-2009, 07:40 PM   #65 (permalink)
Originally Posted by spiki-spikester View Post
As for the front, I fitted slightly stiffer springs & heavier oil and that has made a difference. Not as much difference as changing the internals but a lot cheaper.
I was thinking of doing the same thing, but the one of the problems, as I understand it, is that there is too much compression damping. If this is the case, wouldn't lighter oil be beneficial?
BTW, does anyone know the stock fork oil weight and spring rate?
Old 06-11-2009, 11:59 PM   #66 (permalink)
I'm finding this thread very interesting, but a couple questions:
- how many people have actually adjusted the preload on the stock shock before upgrading and with what results? I just got around to tweaking mine for my 200 pound weight and found a considerable difference! (I'm not a track rider)
- how are you guys feeling about the forks after the shock swap or adjustment?
srfjm is offline   Reply With Quote
Old 06-12-2009, 12:58 AM   #67 (permalink)
Favourite Bike: '99 Ducati Monster 600
Grug's Avatar
Out of interest, would anyone who's changed the suspension components of their Striple have bothered if the Striple R had been around at the time?
Grug is offline   Reply With Quote
Old 08-17-2009, 01:10 AM   #68 (permalink)
Lowering Link
I fitted a Daytona shock on my striple last week, got it dialed - and wow... the difference is astounding. I'm 200 pounds, so the stiffer spring is right for me. Now I need to deal with the forks...
Anyway I was wondering how many are using a lowering link... or not? Pros and cons of each? So far I am not, and I do notice the changed riding position - higher in the rear. It does seem to go into the turns nicer... but I still need to get used to it. I guess my main concern is that the higher rear may exacerbate the issues with the forks.
Any experience or thoughts on this?
Old 08-17-2009, 09:27 AM   #69 (permalink)
Diego's Avatar
Might want to read this thread in a little more detail. Lowering links have been mentioned a few times in it already.
John
Old 08-17-2009, 12:24 PM   #70 (permalink)
Thanks for the help Diego. I've read it from top to bottom a few times... just wondering how many people went through the Daytona shock upgrade process and decided they didn't need the lowering link or want it - or did. The rear end height difference has certain advantages and disadvantages.
Progressive 440 Shock Thread - disappeared?? ssjones Twins Talk 11 03-26-2006 07:38 PM
rear shock upgrade cak03 Sprint Forum 15 01-30-2006 05:56 PM
Rear shock upgrade TorqueyT Tiger Mods & Bolt-Ons (archive) 9 01-23-2006 03:35 PM
Rear shock upgrade Sprint Forum 0 03-29-2004 10:57 AM
