Old 01-11-2008   #1 (permalink)
Favorite Bike: 2008 Street Triple
torque wrench?
i'm going to install my own flyscreen on my striple. the instructions call for a torque wrench in order to ensure that the bolts are tightened to 3Nm. do i actually need to go buy a torque wrench or is triumph just being super safe for liability reasons?
Striple is offline   Reply With Quote
Old 01-11-2008   #2 (permalink)
Favorite Bike: 2006 Triumph Speed Triple
BigRedandRiding's Avatar
Other Motorcycle: 2003 Triumph Speedmaster
3nm is pretty light, torque-wise. I think it may be equal parts liability and desire not to crack the flyscreen. Use loctite and don't over-tighten and you should be fine.
That said, a good torque wrench(say, scaled up to 100nm) is nice to have in the shop for things like bars risers, engine bolts and anything that involves aluminum (soft metal) threads.
-CT
2006 Speed Triple - Fusion White / Pazzo/Rizoma/K&N/LSL/Motovation/Micron CF Race Cans
2003 Speedmaster - Red & Black / 125/42 Jets/AI Removed/K&N /17T Sprocket/Custom Straight Pipes/Ceramic-Coated Headers
BigRedandRiding is offline   Reply With Quote
Old 01-11-2008   #3 (permalink)
MotT3's Avatar
3NM is Very light. just nip them up, don't give it "force" just until you feel it bite a little. Loctite (ie thread lock is not a bad idea) as previously mentioned.
I also agree a torque wrench if you intend to carry out regular maintenance on your steed is a must...well for me anyway.
www.mottleybiker.com
MotT3 is offline   Reply With Quote
Old 01-14-2008   #4 (permalink)
thanks for the response!
Old 01-18-2008   #5 (permalink)
Favorite Bike: For which purpose?
BonnieGreenDon's Avatar
Other Motorcycle: '05 BMW 1150 RS (24K mi
Extra Motorcycle: '02 HD Dyna (87k miles)
Conversion ratio
Is there a formula or scale available to convert ft/lbs to NM?
The torque wrenches I have looked at only have ft/lbs scale.
'07 Bonnie Black plus TORS, Bellmouth, K&N, 19t: minus AI, Restrictor plate, CA emissions. About 160,000 miles on the road since 2002.
BonnieGreenDon is offline   Reply With Quote
Old 01-18-2008   #6 (permalink)
i'm sure there's a plethora of web sites with online conversion calculators and/or scales. just do a google search. i always just use google directly for a specific conversion. just go to google.com and type in 'XX foot pounds to newton meters' or 'XX newton meters to foot pounds'. at the top of the search results page it will have the conversion listed.
Old 03-31-2008   #7 (permalink)
Favorite Bike: '06 scrambler
sjalex's Avatar
Other Motorcycle: 1980 Vespa P125X "superstock"
google really is the best tool for that.
that being said, the conversion is:
1 ft. lb. = 1.35581795 Nm
1.4 Nm is probably close enough for most applications.
Since you're working with a wrench calibrated for ft. lb. though you'll want the reciprocal:
1 newton meter = 0.737562149 foot pounds
so multiply the specification in Nm by .74 and there's your wrench setting in ft. lbs.
Why do I like motorcycles? Because I've never been able to leave well enough alone.
sjalex is offline   Reply With Quote
Old 04-01-2008   #8 (permalink)
LeMans's Avatar
Most torque wrenches will royally screw up such a light setting. Don't forget that such tools are most precise around the middle of their scale.
Most of the time the top and bottom 20% of the scale are going to be off the most.
3Nm is 26.55 Lbin, way too low for most wrenches -unless you have something like a Park Tools torque wrench for bicycles handy.
Even if you do, I would just do it by hand and secure the bolts with blue loctite.
For torque conversions, you can use: http://hemsidor.torget.se/users/b/bo...2_e.htm#torque
LeMans is offline   Reply With Quote
Torque Wrench Gwiaz Twins Technical Talk 6 08-03-2007 11:32 AM
torque wrench CCR Modifications & Workshop Talk 11 06-03-2007 08:12 PM
torque wrench bung1 Twins Technical Talk 9 01-02-2007 07:28 AM
torque wrench ? Colonel_Dorkus Twins Talk 10 05-28-2006 02:14 PM
Best Torque Wrench? MaxH Modifications & Workshop Talk 22 06-07-2005 10:15 AM
