My design for a rear rack is moving along. I'm using the 2 - 5mm hard points on the side of the seat just forward of the grab strap, bridging that with a machined lateral brace. At the aft, under the seat I'm using the 2 - 6mm bolts that bolt into the subframe. It's a triangular piece that comes out under the seat and provides a single mounting point, so the aluminum plate that will form the rack will be well supported for moderate loads. I'll also have some lashing posts under the plate to accept bungees or whatever. Pixs as soon as I get the front brace finished (roughed out presently). The rack plate will have to wait for me to source some stock or we do a job in the shop that involves said material.
