Motorcycle.com
Old 11-13-2007   #11 (permalink)
Favorite Bike: Street Triple
Just a side issue Ray.... where did you buy your triple from?
Adamcheck is offline   Reply With Quote
Old 11-13-2007   #12 (permalink)
Newbie
I think, and i would like to know, if Triumph has to change the component.
It isn't right that we have to pay for Triumph...if i have a crash according to me Triumph has to pay.
Sorry but i care fo the problem that i consider very serious...
scardabianca is offline   Reply With Quote
Old 11-13-2007   #13 (permalink)
Hagon do fairly cheap but good shocks.
Reppyboyo is offline   Reply With Quote
Old 11-13-2007   #14 (permalink)
Diego's Avatar
> So it would seem that this problem with the rear shock is common
Because it has been reported two places on the Internet?
C'mon now (pun intended), time for a little perspective. Common, no, not yet; even the bike itself can't be said to be common at this point. More than coincidence, though... probably.
Alas, if some of the supersport naysayers who were disappointed because this is not a naked Daytona turn up here, I imagine they'll have a field day with the "cheap parts" talk again for a while. But there's a difference between a design decision they personally don't agree with (lack of damping adjustments...like every bike I owned until 2003) and what may indeed be a batch of faulty seals. Two quite different matters.
Defects can occur in any mass production environment, and you often don't find out until some of the components actually do fail. In 2005, when coolant return hoses blew up on some of the new 1050cc engines (and 955s that were built in the same cases) did Nervous Nellies immediately bemoan the cheapness of Speed Triples and Sprints and Daytonas? No. And while that was a much less expensive part to begin with, its failure was almost guaranteed to have much more drastic consequences! Triumph had to replace a few engines. You could not tell by inspection whether the hose was likely to fail, and if it burst at highway speed there was a very strong possibility the engine would sieze by the time you could reach the roadside. That's why Triumph ordered a recall.
You needn't worry, scardabianca. Even though the shock is a more expensive component than a hose, it is fully covered by Triumph's warranty. Seal leakage in a shock normally can be seen easily enough during routine inspection, and you will also notice a change in its characteristics while riding. If that happens, it is a nuisance to have to wait for the repair, of course. But you should always stop riding and have the bike checked by a qualified mechanic if you notice any difference in handling anyway, whatever the cause. Correct?
We should all remember the risks of being "early adopters." There are quite a LOT of people who won't buy a first or second year model of any car or bike, because there are always an unknown number of bugs to be worked out. That's an immutable fact of life. We are not exempt just because we wanted this model badly enough to be first in line. We embarked willingly upon this adventure together with Triumph, and we will all be in the same boat with them until any leaks (literal or figurative) are sorted out. And of course, we all want them to be sorted out.
Triumph are pretty good at dealing with issues of this sort. It won't be overnight, but they do act when they see unusual warranty claims. The moral of this story: If yours begins leaking, get your dealer to replace it under warranty first, even if you ultimately plan to install something else later. That way it will be brought to Triumph's attention in the quickest and most effective way.
John
Diego is online now   Reply With Quote
Old 11-14-2007   #15 (permalink)
Raining on the Parade?
I tend to agree with you, John. After all, in the Fall of '04, I used to be suspected of being Triumph's secret "plant" of "mole" (sic) on new RocketIII sites, whenever I invited similar, early adopters not to blow minor disappointments or irritants out of proportion."Misery searching for company" versus "don't worry... be happy"....
Yet, in hindsight, I'd submit that it's indeed the dubious privilege of early adopters to experience such episodes. And to talk about them if they wish to do so.
Isn't it one of the reasons forums such as this one are for??? Jamie.
Jamie is offline   Reply With Quote
Old 11-14-2007   #16 (permalink)
Diego's Avatar
The early adopters' lot is not always an easy one, that's for certain. And forums are indeed for discussion. I don't think anyone's questioning that.
One only hopes it will be factual and balanced; otherwise, it ceases to be a discussion and turns into something less productive.
John
Old 12-16-2007   #17 (permalink)
ray'striple's Avatar
Sorry not replied before now - been going through Chemotherapy.
Triple bought at Shirlaws Aberdeen who have been excellent throughout this episode. They have replace all parts of the rear suspension including the linkages and sent them off to Hinkley for a thorough investigation. (still no update form Hinkley though)
800 or so miles done now and up to the 8000 rpm cant wait 'til I can open it up fuilly - road conditions wont let that happen this month.
ray'striple is offline   Reply With Quote
Old 12-16-2007   #18 (permalink)
Jon.sb's Avatar
Good luck with the Chemo Ray.
I work for a linac (Radiotherapy equipment) manufacturer so I spend my time in quite a few cancer centres throughout Europe.
Good to hear that the dealer and Triumph are taking care of your bike while th doctors you out. I have to say that my experiences with Destination Triumph down in Ashington have left me equally impressed with the brand and their dealers.
I had th throttle cable adjusted because I wasn't happy with how it seemed to become more "snatchy" thanks to the cable stretching and in these cold conditions I didn't need that!
I ran down to the dealer the other day and the workshop fiddled while I warmed up with a complimentary coffee! Maybe it is psychological but I sware that the adjustments made a lot of difference and I was able to increase the revs as a result of passing 300 miles to boot! ;-)
Geat day even if it was bl00dy freezing!
Jon
http://www.stormbroke.talktalk.net/strippy.htm
Jon.sb is offline   Reply With Quote
Old 12-16-2007   #19 (permalink)
Favorite Bike: Very fast 675
Will's Avatar
There are going to be a few teething problems, but my experience is Triumph does as good a job, maybe better, than other manufacturers in making sure they are minimal. The oil consumption issue on early 675s is a good example. I would be very surprised if any Street Triples used much oil at all. Two leaking shocks seems like a big problem if you have one, but overall, Triumph seems to be doing pretty well. When it comes to dealing with similar issues, resolution often seems to boil down to how well your dealer supports you.
Will
Old 12-16-2007   #20 (permalink)
Thumbs up
Cheers for that Jon, I have to agree that the quality of service and advice from Triumph workshop ie Shirlaws' has been faultless. And with only a leaking seal (-probably -) on a new bike they Triumph are doing fine too.
And no Will the Street Triple uses V. little oil in the 880 miles so far, I do have a litre waiting though.
Was oot too today and the triumph gear kept me warm too but it was bloody cold but worth it a bra sunny winters day.
Stay safe
Ray
South Florida Great Ride 400 miles bichomalo Speed Triple Forum 6 03-22-2007 10:17 AM
Rear shock Chadillac Hinckley Classic Triples 12 03-08-2007 09:47 PM
Slow leaking rims - front and rear!! Healey_100 Club Cafe 12 02-11-2007 07:50 AM
Rear Shock tbirdtroy Hinckley Classic Triples 8 10-09-2005 12:43 AM
Leaking rear shocks crazypierre Classic, Vintage & Veteran 10 06-14-2005 08:51 AM
