Cig outlet on stripe?? - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com
Old 12-11-2012, 10:04 AM   #11 (permalink)
Originally Posted by SkyAdam View Post
I just put a 12v outlet in the Radiator cowl. The kit is sealed with a rubber cover and the power wire is fused. I did have to extend the positive wire to reach the battery under the tank. Haven't had any issues but haven't been caught in a full on downpour since putting it in either.
This is what I bought:
http://www.amazon.com/gp/product/B00...ls_o02_s00_i00
Picture please!
Neanderthal is offline   Reply With Quote
Old 12-11-2012, 09:52 PM   #12 (permalink)
Main Motorcycle: '00 TBS
petermholmes's Avatar
Other Motorcycle: '09 ST3R
Extra Motorcycle: WTB: Metralla GTS
I mounted a Powerlet in the front of the right rear panel (little $234 plastic ditty that helps keep heat off the passenger's legs, the thing with the "Street Triple" decal on it). I run heated clothing in the fall and spring, so that makes a nice location to plug in (I keep the controller in my right jacket pocket).
petermholmes is offline   Reply With Quote
Old 01-15-2013, 09:49 AM   #13 (permalink)
Main Motorcycle: Working on it
Thanks for all the replies. The main thing i want it for is to charge my phone as i it for turn by turn directions and have it bluetooth connected to my helmet intercom.
nickrp83 is offline   Reply With Quote
Old 01-16-2013, 12:23 PM   #14 (permalink)
Main Motorcycle: '12 Street Triple R
Other Motorcycle: '10 Ninja 250
This is what I have
From the battery
Amazon Amazon
With this USB outlet
http://www.burnsmoto.com/usb-power-s...atherproof.php
Phone sits in this on my bars in this mount.
http://www.rammount.com/Products/AQU...5/Default.aspx
I bought the large box and it is large enough to accomodate my phone with a charger plugged into it.
01xj is offline   Reply With Quote
Old 01-17-2013, 08:16 AM   #15 (permalink)
01XJ, does that setup drain your batt when it isnt turned on (and you have nothing pluged in of course)? how did you conned the USB plug? or does it just hang free?
Old 01-17-2013, 09:38 AM   #16 (permalink)
Main Motorcycle: street triple R
That USB plug will draw power constantly, as will any other device that drops voltage down from 12v to a lower voltage. It won't draw much with no devices plugged in, but it will drain a weak battery if it just sits for a few weeks.
Lush_trucker is offline   Reply With Quote
Old 01-17-2013, 11:57 AM   #17 (permalink)
How can a USB plug draw power on it's own if no device is plugged into it?
Old 01-17-2013, 01:58 PM   #18 (permalink)
Because it uses a transformer to drop voltage from 12v to 5v, your phone charger plugged into the wall at home pulls juice for the same reason, even when your phone isn't plugged in.
If you are worried about it, you should just get a cig outlet or other standardized 12v outlet, and an appropriate charger, unplug the charger when you aren't using it.
Old 01-17-2013, 02:21 PM   #19 (permalink)
If nothing is in use there's no draw to require a voltage drop. I've used this set up for a year and never even had a sliver of an issue.
To answer your question Nick- I have never noticed any drop in voltage. I use the same setup on both my bikes and have never had an issue. I run GPS and my phone charger off it and it works great. I just had my bike sitting for a month and it started right up for me when we had some warm days last week.
Old 01-17-2013, 08:14 PM   #20 (permalink)
You don't have to believe me. Use a multimeter and check for current draw. It may never cause a problem, but if it uses a transformer to drop voltage, it does draw current constantly.
checkerboard stripe KD5QOQ Hinckley Classic Triples 1 05-23-2009 02:27 AM
Pin-Stripe example dave1068 Twins Technical Talk 6 10-14-2007 10:00 PM
Racing stripe rvman Twins Technical Talk 6 03-27-2007 07:36 PM
Seat stripe? Panthermark Twins Technical Talk 18 03-06-2007 06:48 AM
Stripe? tham Club Cafe' 6 06-05-2006 09:35 PM
