Will a GSXR 600 shock fit on a Street Triple? - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com
Old 12-04-2012, 10:09 AM   #1 (permalink)
Main Motorcycle: 1973 Tiger 750
jonkull's Avatar
I totaled my SV650 last month and just put a deposit down on a Street Triple. One of the things I salvaged from the SV is an Elka 3 way adjustable rear shock that fits 01-03 GSXR600s and 03-07 SV650s. I've seen a few posts about CBR and Daytona rear shocks on the Street Triple but no mention of the GSXR. Does anyone know if this would fit?
jonkull is offline   Reply With Quote
Old 12-04-2012, 06:41 PM   #2 (permalink)
Main Motorcycle: 2010 Street Triple
bira's Avatar
I don't know for sure, but if the Elka shock is close to the same total length and travel of the stock STD or "R" shock then there is a good chance it might fit. But likely not without some spacers, etc. After a quick look at Elka's site, it looks like the overall length of their shock for the SV and the Striple is the same. It does not indicate shock travel, but as they are the same overall length that's likely close. That's the good news. Now it just comes down to how different the widths of the mounting "hardware".
Modifications so far:
Axxiom valve kit, Traxxion spring kit
CBR600RR shock
Tail Tidy, Triumph bar end mirrors
FP Racing levers, -1 front sprocket
bira is online now   Reply With Quote
Old 12-04-2012, 06:53 PM   #3 (permalink)
Main Motorcycle: '10 ST3R
Orangeman's Avatar
I would contact Elka or an authorized service center. If not a direct fit it may not be all that complicated to have it re-built and correctly sprung/valved for your new bike much cheaper than a complete new shock. I have had Penske units re-fitted for other bikes, see no reason why Elka can't do the same.
Although if it's this one :
The piggyback reservoir will have to be changed to a horizontal unit or remote. As is, if you look at mine you can see it would hit the swing arm.
.....My Bike
Orangeman is offline   Reply With Quote
Old 12-04-2012, 06:58 PM   #4 (permalink)
bira's Avatar
Originally Posted by Orangeman View Post
...if you look at mine you can see it would hit the swing arm.
Man that thing is clean!
CBR600RR shock
Old 12-04-2012, 10:59 PM   #5 (permalink)
jonkull's Avatar
That's pretty funny. It is literally this one. I bought it from the guy that posted that picture a couple of years ago.
I guess I'll just contact Elka and see what they say.
Old 12-05-2012, 03:57 AM   #6 (permalink)
Main Motorcycle: 09 street triple
rallycat's Avatar
Other Motorcycle: Tamiya 1/12 scale MHR Duc
I seem to remember that the Suzuki linkage is different than Triumph & the spring rate is lower. As Orangeman says call Elka; they'll know.
If the eye-eye shock length can be adjusted to 290-295 mm then length is ok, lower mount has to be changed from that clevis to a bushing, & both bushings are 30 mm wide with a 10 mm hole.
That piggyback reservoir would be trying to occupy the same space as the exhaust, regardless of whether it would hit the swingarm.
rallycat is offline   Reply With Quote
Old 12-05-2012, 01:53 PM   #7 (permalink)
Orangeman's Avatar
That's pretty funny. It is literally this one. I bought it from the guy that posted that picture a couple of years ago..
That's what happens when you use the same screen name on multiple forums
http://www.socalsvriders.org/forums/...ad.php?t=30157
.....My Bike
Old 12-05-2012, 09:38 PM   #8 (permalink)
jonkull's Avatar
Elka says buy a new shock. Oh well...
675R shock in my Street Triple! timmmay Street Triple Forum 20 04-07-2012 12:21 PM
GSXR to Street Triple? under200 Street Triple Forum 24 07-24-2011 08:01 PM
Daytona Shock on Street Triple Settings mejetski2000 Street Triple Forum 2 03-18-2011 04:17 PM
new girl, went from a GSXR to a Street Triple R shinday Street Triple Forum 22 03-29-2009 10:25 AM
