Mirror Adjustment Advice - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-02-2012, 07:25 PM   #1 (permalink)
Main Motorcycle: Street Triple R
Keyzer1980's Avatar
Hey guys,
I was wondering if anyone had come across any studies/advice columns that suggested the correct mirror position for street riding, and if so, did they suggest a good way to position the mirrors?
I am currently running the stock mirrors (12' Street Triple R) and they occasionally get bumped in the bike parking area at work. I was riding home the other day (frustrated at trying to get the mirrors positioned back to exactly where I like them) when I thought - is "where I like them" actually a "correct" position for the mirrors? Is there even a "correct" position? Logic would tell me that it is a what works for you scenario. But still?
Two things came to mind - with the infinite number of adjustment positions available to the stock mirrors - has anyone come up with a guide as to positioning the mirrors? For example, is there anything floating about on road safety suggesting that, for example, you should be able to see a complete car (equally) in both mirrors when they are directly behind you at 30 yards?
The second point leads me back to the mirrors being bumped and the frustration of getting them back to "where I like them". Does anyone mark their mirrors/stems with small lines at axis points so when they are bumped you simply just need to line up the markings to get them back into the "right" spot?
Cheers!
Keyzer1980 is offline   Reply With Quote
Old 12-02-2012, 09:16 PM   #2 (permalink)
Main Motorcycle: '12 Street Triple R
Other Motorcycle: '10 Ninja 250
I just point them so I can behind myself and to either side.
01xj is offline   Reply With Quote
Old 12-02-2012, 10:36 PM   #3 (permalink)
Main Motorcycle: street triple R
I'm not as concerned with directly behind me as I am behind and to the sides, I try to get as little overlap in what they show as possible.
Lush_trucker is offline   Reply With Quote
Old 12-02-2012, 11:01 PM   #4 (permalink)
Main Motorcycle: '09 Sprint ST
SLY DVL's Avatar
The mirrors on my Sprint have a detent built into the stalk so if they do get bumped it's simply a matter of moving them back to the detented position.
As for placement, I like to be able to see just the edges of my arms. That gives me a reference point when trying to decide where an object in the mirror actually is. I've tried pointing them right at the blind spot but just can trust what I see since I have no point of ref. to compare it to.
Having said that, I've done this to several of my bikes...
Kevin
It always takes at lease twice as long to fix a mistake as it does to make one...
SLY DVL is offline   Reply With Quote
Old 12-03-2012, 08:40 PM   #5 (permalink)
Keyzer1980's Avatar
Hey Sly,
That is a good idea with the blind spot mirror - there is a reason why trucks use them!
I think I will just stick to what works for me if there is no consensus on the 'best' positioning for mirrors. I thought it would be the case I have to say!
Old 12-04-2012, 01:20 PM   #6 (permalink)
Main Motorcycle: street triple R 2012
zyhano's Avatar
use one for behind and one to give you a view on the fast line for when you're starting to overtake.
use one to monitor traffic that might get you from the same lane, the other to get a look if its ok to start overtaking. always use your head to look at the blind spot sideways/behind you when overtaking
as said earlier, try to not get any overlap and use the mirror for overtaking on the side you're going to move into.
adjust to what works for you, depending on speed and position adjust them sccording to riding style
Sent from my Motorcycle idevice
stripleR12 + techspec c3 + oxford heated grips + gb racing full protection - passenger pegs + 12v attachment + cheap shorty levers + kriega all over + gopro radiator cowl mount + gerbing electrics + full insurance + dunlop sportmax sportsmart
zyhano is offline   Reply With Quote
Mirror stalk adjustment luigi Speed Triple Forum 4 03-22-2010 07:36 AM
Help - Need bar end mirror advice jcf66 Twins Talk 3 05-31-2009 07:27 AM
Mirror adjustment Ogre Street Triple Forum 0 05-03-2009 09:38 AM
Prior mirror post/ advice onetufTop Twins Technical Talk 12 07-19-2006 03:51 AM
mirror advice please jaben Hinckley Classic Triples 7 12-22-2005 02:16 PM
