Originally Posted by bira
You mean you've used this particular product? If so, what do you think of it?
BTW, I can't make my mind up if I want to get two and keep the high-mount exhaust or get one and convert to a low-mount, 3-1 setup.
I have used many parts from Cone Eng.
The merge collector kits are a pretty good deal for the price. They are formed from sheet metal that was first welded into a cone shape, then pressed into a collector shape. It is probably not the BEST design, but it is better than stock IMO.
It would be tough to use one of their 2 into 1 collectors on a Street Triple for the under tail section. It is not really designed to have the 2 pipes split off at such a high angle. If you fabbed the entire system it would probably work ok, but it would be difficult to use if you plan to add it to the existing twin pipes, or any aftermarket twin pipes with the same dimensions.
