520-525 or 530 chain??? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-23-2012, 08:52 PM   #1 (permalink)
Main Motorcycle: 2013 Tiger 800 XC
Is the street have a 520, 525 or 530 pitch chain??
Thank you
David L. is offline   Reply With Quote
Old 11-24-2012, 12:24 AM   #2 (permalink)
Main Motorcycle: 06 Thruxton
roxythruxton's Avatar
Other Motorcycle: 76 CB750 86 Yammie SRX-6
It's a 525 .
Some folks change the chain to a 520 . I've tried it . Never noticed a difference .
Long Live The Limey:D
BIR#220
Blue Knights Chapter XX
Green Knights Chapter 50
Yep. I've got some mods .
roxythruxton is offline   Reply With Quote
Old 11-24-2012, 12:46 AM   #3 (permalink)
Originally Posted by roxythruxton View Post
It's a 525 .
Thank you Roxy!
No it's not to change for a 520 (i've did it on my speed triple and it's a waste of money). I want to know it because i have a 2013 street triple on the way, and i want to order a front sprocket -1 theet, so if i don't like the new longer first speed on the new model, i'll change the front sprocket.
Old 11-24-2012, 06:19 PM   #4 (permalink)
Maybe try out the stock gearing for a while; changing sprocket teeth will make the speedo very inaccurate which can be quite annoying on the road. Only fix is TuneEcu. IMO a 49T rear is better gearing giving even stronger top gear roll-on and the same top speed cos it will rev higher in top gear. The smaller front sprocket is harder on the chain and slider too. - Wayne
Wayne's Striple is offline   Reply With Quote
Chain Break kit / Chain size question Redrider736 Sprint Forum 15 04-30-2011 06:13 PM
chain chain chainnn - chain for my bonnie convict Twins Technical Talk 16 06-28-2010 04:19 AM
Chain adjustment? My chain is too slack, cant adjust. roadkill Speed Triple Forum 12 06-17-2010 04:30 PM
Replace Chain and sprockets, still have a tight spot in chain toecutter Sprint Forum 10 05-28-2009 11:07 AM
