Paint/ Color codes - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-17-2012, 02:27 PM   #1 (permalink)
Main Motorcycle: '12 Street Triple R
Other Motorcycle: '10 Ninja 250
Paint/ Color codes
I recently ordered an unpainted rear hugger from Simpson Detour. I went with unpainted because I figured it would be easy to find an aerosol version of the Diablo Red. Turns out, the only thing I can find is from ColorRite.com- it's not aerosol and it's pretty dam expensive. A half quart starts at almost 100$. Seems a bit much to paint a 50$ piece of plastic that's going to spend it's life covered in road grime.
I have searched google and the forums fairly extensively. Can't come up with a darn thing about Triumph paint codes, other than classic models. I even called a certified Triumph dealer and all they were able to do was find the product code for a 20$ touch up pen. No actual color code. I would like the color code for the actual paint color, because a local place will make me an aerosol can which I can use to spray my hugger.
Anyone able to help me out?
01xj is offline   Reply With Quote
Old 11-17-2012, 04:21 PM   #2 (permalink)
Main Motorcycle: street triple R
What color is the plastic? I ran the triumph black plastic hugger for a long time, then covered it in 3m di-noc
Lush_trucker is online now   Reply With Quote
Old 11-17-2012, 04:52 PM   #3 (permalink)
Main Motorcycle: '10 ST3R
Orangeman's Avatar
ColorRite does have 2012 Triumph Diablo Red (#1043) in a spray can for $33.95
http://www.colorrite.com/product/1043-base-1173.cfm
You will also need a clear to do it right.
.....My Bike
Orangeman is offline   Reply With Quote
Old 11-17-2012, 06:20 PM   #4 (permalink)
AFAIK it is unpainted ABS style plastic. It is coming from the UK from Simpson Detour.
I figured the base coat would just be a primer, no? Would that number, 1043 be a ColorRite specific number or is that the universal paint code?
Shows you how much I know about automotive paint.
Old 11-17-2012, 06:37 PM   #5 (permalink)
Orangeman's Avatar
Primer is primer and your hugger is advertsed with a "paintable base" already applied so should not be needed. Base coat is your main color, followed by a gloss clear coat.
Triumph Diablo Red is suppied by Standox as the following formulation:
Manufacturer : TRIUMPH MOTORCYCLES
Code : CW
Color name : DIABLO RED
Panel No : Q8937
Panel No : 861248
Var. :
Color Change :
Paint system : STANDOBLUE BASECOAT
Coat : 2 COAT
Finish type : Gloss
PB :
VS : 2
Standard Date : 28/07/2010
Formulation Date : 13/09/2012
Revision :
Form-No : 7216210
The minimum amount is 0.25 litre! Smaller amount can cause colour accuracy problems.
Paint system: STANDOBLUE STANDOHYD BASECOAT STANDOX BASISLACK
Region: EUROPE EUROPE
Paint system Region Panel No Version Coat Finish type VS Type Chip Position Actions
STANDOBLUE BASECOAT EUROPE 861248 2 COAT Gloss 2 Solid -
PG II
+ 10% STANDOBLUE VISCOSITY ADJUSTER
Mix Description gram (abs.) gram (cum.)
STBLUE 190 SPEZIAL-ZUSATZ 693.4 693.4
STBLUE 168 MAGENTA 72.8 766.3
STBLUE 165 BRILLANTROT 216.0 982.2
STBLUE 169 PURPUR 61.5 1043.8
STBLUE 182 SCHWARZTONER 0.8 1044.6
Sorry...that's all the informaton I have
.....My Bike
Old 11-17-2012, 07:03 PM   #6 (permalink)
Code : CW
Panel No : Q8937
Panel No : 861248
Var. :
Color Change :
Coat : 2 COAT
Finish type : Gloss
PB :
VS : 2
Revision :
Form-No : 7216210
PG II
Thanks so much. That just saved me a bunch of time and money! I was hesitant to order the base coat since I thought it was the primer coat.
Old 11-17-2012, 08:37 PM   #7 (permalink)
Automotive paint is totally different from normal rattle can stuff. As previously stated, you will need to get clear coat to go over the base coat, and the application process is different too. You might want to do some more research before you waste a bunch of time and money.
Old 11-17-2012, 09:04 PM   #8 (permalink)
I know what to expect from my rattle can job. No need to break the bank painting it. It will look fine with several base coats and several clear coats. Obviously not as nice as factory paint, but after all it's a dirt deflector not a work of art.
paint color and codes KOOWEE The Welcome Center 0 08-24-2012 05:36 PM
Truimph Paint Color Codes Musicman58 Sprint Forum 14 01-05-2012 09:01 PM
Color Codes--Help RedBird Maintenance & Workshop Talk 6 07-29-2005 11:07 PM
Paint job / color codes TorqueyT Tiger Chat 2 06-13-2005 07:11 AM
Color codes Hinckley Maintenance & Workshop Talk 52 03-08-2005 07:28 PM
