Front brake pump/vibrations/chatter - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!SportbikeTrackGearMotorcycle.com
Old 11-13-2012, 05:36 PM   #1 (permalink)
Newbie
Main Motorcycle: 2012 Street triple
I have owned my street triple R since new and currently have circa 850 miles on the clock. However, since new i have had a front brake pump/vibration/chatter issue. Typically the pump comes in as i am about to come to a stand still, along with a front brake squeel. The vibrations are so bad it will knock a filling out. In fact it is as if the ABS is kicking in, exactly it has no ABS. I have it booked into my local dealer who think sit may have something to do with the front disc/rotar. There is apparently a known issue of some defaults on the front disc. To say that i have zero confidence in braking is an under statement. Was wandering if anybody else has had a similar issue or may have an idea of what it may be.
Thanks in advance for your help.
gsylvester78 is offline   Reply With Quote
Old 11-13-2012, 06:18 PM   #2 (permalink)
My 2010 R has 22000 kms on it and the Nissin radial front brakes are always superb; smooth and firm. The pads still have a long way to go. Something is defective assuming the brakes have been properly bled (improper bleeding usually results in a spongy feeling but not vibrations). The brakes/rotors need to be checked for proper assembly and defects. Check that wheel bearings are tight. You should have gone back to the dealer immediately at the first sign of brake trouble but warranty should cover it. Make sure they install new pads if new rotors are installed. The front brakes are fantastic when working properly and broken in. - Wayne
Wayne's Striple is offline   Reply With Quote
Old 11-14-2012, 04:40 AM   #3 (permalink)
Main Motorcycle: street triple R
Sounds like a rotor issue to me, possibly warped.
Lush_trucker is online now   Reply With Quote
Old 11-14-2012, 05:26 PM   #4 (permalink)
Main Motorcycle: Street Triple r
Other Motorcycle: 2010 Street Triple R
As said, it could be a warped brake disc/rotor, or something as simple as the pin holding the brake lever on needing greased.
As for the squealing, that's more than likely your brake pads needing a bit of copper grease on them.
simondo_01 is offline   Reply With Quote
Old 11-15-2012, 01:34 AM   #5 (permalink)
Main Motorcycle: TRIUMPH T140E
ARTY's Avatar
Other Motorcycle: BSA B44 Victor
Extra Motorcycle: Triumph Street Triple
Yes I would go with the Disc being warped and the addition of Copper slip grease to eliminate the brake squeal !.
The first port of call is take it back to the dealer to have it checked out if it is still under warranty .
ARTY is offline   Reply With Quote
Old 11-15-2012, 09:52 AM   #6 (permalink)
Where are you guys putting the grease? I've never put grease on my brake components.
Neanderthal is offline   Reply With Quote
Old 11-15-2012, 12:04 PM   #7 (permalink)
ARTY's Avatar
Smile
I have just recently changed all the brake pads on my Street triple - regrading the use of grease :
First of all I used an aerosol of disc brake cleaner to clean all parts of the Brake Caliper when removed from the bike and discarded the old pads .
I smeared the outer walls of the brake pistons with Red Grease & pushed them back into their caliper then , I smeared the back of the Brake pads with Copper slip Grease as well as the Pad retaining Pins .
Old 11-17-2012, 04:52 AM   #8 (permalink)
Main Motorcycle: Street Triple R
ZrexRich's Avatar
I was having the same issues (chatter/pulsing feeling just before a complete stop) until I cleaned the brake calipers/pistons/rotors with 70% isopropyl (rubbing) alcohol and some Q-tips and rags. It's inexpensive and most supermarkets should carry it.
ZrexRich is offline   Reply With Quote
Front Brake Chatter at low speed?? New 2012 bike elvisboy77 Street Triple Forum 15 05-11-2012 03:44 AM
Thruxton Front End Chatter Wolfpack94 Twins Technical Talk 11 10-21-2011 12:45 PM
2011 ABS cuts in early, brake vibrations martin2011 Speed Triple Forum 6 08-24-2011 04:19 PM
I have a new front brake pump installed :D zuzka600f Sprint Forum 48 05-06-2011 01:23 PM
front end chatter earl Maintenance & Workshop Talk 5 08-10-2006 07:09 AM
