2012 R cold starting problem - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-09-2012, 06:57 PM   #11 (permalink)
Main Motorcycle: 2012 Street Triple R
dementedbrave's Avatar
fuel pump, interesting. although i think my problem is battery related, i am using a lightweight lithium one and i think maybe the voltage drops too much when its cold. Never had a problem starting in the warmer weather.
dementedbrave is offline   Reply With Quote
Old 11-16-2012, 03:31 AM   #12 (permalink)
Main Motorcycle: street triple
Originally Posted by Wayne's Striple View Post
The lithium batteries don't like cold weather starting until the ions get revved up. That is why it starts on the second or third try, and is why I am using the strong Shorai18Ah model. http://www.ballisticparts.com/downlo...deo/video2.php The oil pressure light and check engine light won't turn off until the engine starts. With the Shorai, the 18Ah is the same size as the 12 and 14Ah models so no problem fitting. The Ballistic 12 cell would be a better choice for cold weather if it would fit cos it is a pain waiting for the Striple to go through the reset procedure before attempting starting again. Sometimes leaving the lights on for a minute or so before starting helps. IMO the standard recommended lithium battery is fine for warm climates but not for temps below 50F. Even the standard lead-acid battery loses a lot of cranking power in cold weather and gets worse the longer you crank it unlike a lithium battery which does the opposite. - Wayne
Wayne, I just ordered SHORAI LITHIUM ION BATTERY YAMAHA V MAX 1700 09-12 LFX18A1-BS12
can you please confirm that this is the right one for street triple?
Many thanks!
apetrov1x5 is offline   Reply With Quote
Old 11-16-2012, 07:06 AM   #13 (permalink)
Main Motorcycle: '10 ST3R
Orangeman's Avatar
Standard Recommendation: LFX14A4-BS12
Duration Recommendation: LFX18A1-BS12
http://www.shoraipower.com/c.3379047...ery-finder.ssp
.....My Bike
Orangeman is offline   Reply With Quote
Old 11-17-2012, 04:14 PM   #14 (permalink)
Thumbs up
thank you!
Old 01-04-2013, 08:34 AM   #15 (permalink)
does one need to charge the battery at home before installing on the bike for the first time?
Old 01-04-2013, 11:16 AM   #16 (permalink)
I believe it comes fully charged, but best to check it with a voltmeter (should never be below 13v, should be between 13.25 and 14.25v). You should use a low amp charger around 1A (that does NOT have a desulphation mode) and carefully check voltage to prevent over-charging. If the battery is already partially charged it should charge up fully in a half hour. Disconnect the battery if the bike is in storage more than a few weeks. - Wayne
Wayne's Striple is offline   Reply With Quote
Old 01-04-2013, 07:09 PM   #17 (permalink)
Main Motorcycle: 2012 Street Triple r
Other Motorcycle: 2011 GSXR-1000
Extra Motorcycle: 2012 Vespa GTS 300 super
It might be apples and oranges but the Li batteries on my Zero S won't charge at all starting at 20 F and charge poorly below freezing. My garage is always 60 F or higher though, even on the coldest of nights, so low temp is never a problem for me.
AJ Nin is offline   Reply With Quote
Old 01-09-2013, 09:33 AM   #18 (permalink)
understood! many thanks!
Cold Starting Problem tritbs1998 Hinckley Classic Triples 6 04-14-2010 12:37 PM
Jump Starting and cold cold temps ztolley The Rocket Science Forum 24 01-15-2010 12:25 PM
2000 Adventurer cold weather starting problem y2ktriad Hinckley Classic Triples 8 10-22-2009 08:31 PM
TR6 continued problem cold starting, but ok when warm clamp007 Classic, Vintage & Veteran 2 04-04-2008 09:02 PM
Cold Starting Problem altlcrzy Twins Technical Talk 3 07-09-2007 11:46 AM
