I did a search on here and there seems to be a few other threads of people with Daytonas having the same issue but nothing I have done that they suggest has fixed the issue. Earlier today I noticed that my clock was reset to 1:00, when I got home I set it to the correct time and turned it off and it reset back to 1:00 again as well as all my trip timers and stuff. I also just realized that my signals dont work so I looked up in the manual about the fuse box and tried the horn and that doesnt work either (must be the fuse). Everything worked wonderfully yesterday. My question is, do you think that the fuse being blown is causing the gauges to reset or is it a bigger issue? I already cleaned the terminals and checked to make sure everything under the set was connected securely. I will replace the fuse tomorrow morning but figured I would ask so maybe I can sleep a little more soundly tonight. Thanks for your help!
(2010 Street Triple, 3200 miles)
